Author Topic: 1978 honda cb550 four k carb rebuild kit  (Read 9862 times)
evanokeson
« on: January 22, 2011, 08:57:26 PM »
im on the search for a rebuild kit for my 550. ive heard they dont make them anymore and a bunch of diffrent things. I figured this would be the place for the answer if there is one.
thanks!
Offline 73hutch
Re: 1978 honda cb550 four k carb rebuild kit
« Reply #1 on: January 23, 2011, 08:37:36 AM »
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline decafe
« Reply #2 on: May 25, 2011, 01:53:57 AM »
thanks!
Any luck buddy, looking to do the same very soon and need rebuilt kits and new jets?
bollingball
« Reply #3 on: May 25, 2011, 04:48:47 AM »
TT is one of the main 550 guys he will know so heres a bump. Maybe some other 550 owner will see this?
Offline decafe
« Reply #4 on: May 25, 2011, 05:25:57 AM »
Thanks bollingball
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: May 25, 2011, 07:42:58 AM »
You can get a gasket kit from this guy on ebay: http://stores.ebay.com/MotorCycle-Solutions it includes the float bowl gasket and the various o-rings for the bowl drain screw, air screw and the aluminum fuel filler connector  tubes that run between the carbs.
I purchased a set for the carbs on my '77.
My bike only had ~7k miles on it, si I did't feel the need to replace the jets and float valve. I just soaked everything in carb dip and blew them out with compressed air.
Full rebuild kits do turn up now and then, but they are definitely harder to come by than the '76 and earlier kits.
Offline clark gable
« Reply #6 on: February 10, 2012, 11:33:45 AM »
I want to revive this thread..i can't find any complete (quality) rebuild kits for a 78 550k carbs anywhere..including the above mentioned sources...anyone know of anything??
Thanks
Offline goodwolf
« Reply #7 on: March 28, 2012, 01:17:46 PM »
Does anyone have a good word on rebuild kits for 78 550k? I'm scouring, but I have had little luck so far.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #8 on: March 28, 2012, 01:21:53 PM »
Have you tried your local Honda dealer...........more money,correct fit,just the rubber bits...
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
« Reply #9 on: March 28, 2012, 03:28:03 PM »
Apart from terrorist attacks (people/corrosion, etc.), it's only the rubber bits that need replacing.
I got this number from Western hills Honda ( I used the 77 CB550K for the search.  But, the rubber kit is same for 78, too.)
GASKET SET
16010-393-305 (replaces 16010-404-004)   004   $15.58
Then I put the number into google and looked at the first hit:
http://www.ronayers.com/ProductDetails/N/687/SKU/235848
2nd Hit Probably european:
http://www.onlinemcparts.com/products/gasket-set-1769310-16010393305.html
Then...
http://www.davidsilverspares.co.uk/CB550K-1977-USA/part_144844/
More:
http://www.cycle-parts.com/Product.aspx?ProductID=1585078&SKU=16010-393-305
http://www.gearhead.com/all/16010-393-305.html#/s/HOM//16010-393-305/1
Offline lucky
« Reply #10 on: March 28, 2012, 08:01:43 PM »
A motorcycle is NOT like a car.
When you buy a rebuild kit for a car carburator you get all the parts you need.
On motorcycles you can just replace the float needles (80% of the rebuild).
Then clean the jets, Especially the idle jet. and set the float level.
Do not replace the float bowl gasket unless it is broken or leaking which is very seldom.
Make sure the needles in the slides are all in the same position.
Adjust the mixture.
Adjust the idle.
Thats it.
