Author Topic: Keihin CR 29 carbs  (Read 4434 times)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Keihin CR 29 carbs
« on: January 26, 2011, 12:23:09 PM »
I guess I'm not as familiar with these carbs as I thought I was.
I noticed that on the sides of #3 and #4 carbs there are these extra spigots:
I thought they might have been the carb bowl vent/overflow outlet but noticed that they are not present on carbs #1 and #2. Looking at the bottom, there are no vents:
I haven't confused these with the fuel inlets because I know where they are. Can anyone tell me what these two extra nozzles are for?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline scondon
  • Mmmm......tasty bugs
Re: Keihin CR 29 carbs
« Reply #1 on: January 26, 2011, 12:34:20 PM »
Pictures are small, but I think you are talking about the air intakes for the choke circuit. There should be one on all four carbs, unless the design has been changed in the past 8 years???
Offline Silverback
« Reply #2 on: January 26, 2011, 01:42:21 PM »
All the CR29 I have seen have them on all four carbs. Odd!
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline scondon
« Reply #3 on: January 26, 2011, 02:53:57 PM »
They do swivel, so maybe the other two are just pointed up/forward and are not visible from underneath?
Offline swellguy
« Reply #4 on: January 26, 2011, 03:28:52 PM »
They do swivel but I swear there aren't any on carbs 1 & 2.
I'll take a closer look and post some larger pics.
Thanks in advance.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #5 on: January 26, 2011, 04:15:08 PM »
Trust me, you have them on all 4 carbs.  Otherwise the carb bank would not work.
Sparty
1972 CB750 K2 Cafe' Style
Offline swellguy
« Reply #6 on: January 26, 2011, 04:20:35 PM »
I do trust you. I had to put on 3x magnifiers to actually see the ones on 1 & 2.
Anyways, here's the better picture:
So they do look like the air intakes for the choke circuits. Since they swivel 360 degrees, I'm wondering if there is an ideal position for them?
« Last Edit: January 26, 2011, 05:38:05 PM by swellguy »
