Author Topic: CB550 or CB650?  (Read 5134 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
CB550 or CB650?
« on: February 10, 2011, 08:35:07 PM »
I want to build a Cafe Racer and I have a 1975 CB550K and a 1981
CB650C. I'm looking for help on deciding which one would be better to start from? Also which carbs would work better?  ( the '81 on the '75??)                           Thanks, Doug
Offline MoMo
  • Ride like you're invisible
Re: CB550 or CB650?
« Reply #1 on: February 10, 2011, 08:38:23 PM »
You will find parts readily available for both.  Why not post photos of both so we can get a better idea as to what you have to start with?  If the 550 is stock and in good condition, I'd restore it and cafe the other...Larry
Offline Doggie
Re: CB550 or CB650?
« Reply #2 on: February 10, 2011, 08:49:29 PM »
Right now both are in a shed covered by 12" of snow. The 550 is stock and the 650 was stock but I took it apart last fall and boxed it up.
                                                          Doug
Re: CB550 or CB650?
« Reply #3 on: February 10, 2011, 09:13:01 PM »
550......just sayin'
Offline Pinhead
  • 1979 CB652-ST
Re: CB550 or CB650?
« Reply #4 on: February 10, 2011, 09:26:09 PM »
The 550s are much more commonly Cafe'd (and are more common in general) because of the relatively "flat" stance of the bike while the '81+ 650s are more commonly chopped/bobbed due to their already "stretched" stance (more rake/trail and a taller/more angled tank from the factory).
The CB650 has a better and more powerful engine though it doesn't have a kick starter (the purists often argue that you can't have a true Cafe bike without a kick starter).
The stock CB650 will make more power than most moderately built CB550s due to a better piston and head design and better ports from the factory. Though if you're rebuilding the engine for power the CB550 has more aftermarket parts. Forum member Soos (CB650 guru) has almost negated that problem, however, with his piston machining projects.
Trying to decide which carbs are "better" will open a can of worms. But Soos has archived various carb options for our CB's (including some Suzuki carbs if I recall correctly). With different carb rubbers, CB750 carbs can be used on the '81+ CB650. I'm not sure about the CB550, though.
I may be a bit "behind" on the aftermarket options of the CB550 so don't take my info as gospel; I have a '79 CB650 so most of my knowledge is of the 650s.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Bluegreen
Re: CB550 or CB650?
« Reply #5 on: February 10, 2011, 11:11:13 PM »
Put the 650 motor into the 550 frame. Find non CV carbs. Problem solved.
Offline Hush
Re: CB550 or CB650?
« Reply #6 on: February 11, 2011, 12:45:01 AM »
Got a sneaky feeling the 650 is a taller motor! ;)
Offline Kong
Re: CB550 or CB650?
« Reply #7 on: February 11, 2011, 06:01:55 AM »
I had two 550s to chose from, in fact still do in a sense because one bike is being built and the other is my parts bike.  I have titles for both of them so that didn't enter into the decision.  One was modified a good bit, and poorly, the other had been modified a little bit and the work was well done.  On was running - barely - and the other was not.
I chose the older of the two bikes (a '77 and a '78) for two reasons.  First because its frame had less rust on it and second and most importantly because it had a tight swing arm.  Probably something to do with the bike's low milage.
I would imagine any number of things could influence your decision on which one to use but you're the only one with the bikes in front of you and know where you want to end up.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Doggie
Re: CB550 or CB650?
« Reply #8 on: February 13, 2011, 08:51:01 AM »
Thanks Guys, Looks like from the feedback that I got on here, that I will be going with the 550. It ran when I got it, drove it around the backyard a little bit, then it quit, and started to leak fuel out of the overflows.
     Right now I am working on a CB650C which I linked up with a Jr. Dragster frame. I brought the bike in for the winter so I could move the front disc and calipers to the rear wheel. Also moving the speedometer housing that was on the front wheel to the rear wheel. Changed the rear spocket from a 39t to a 43 t. Mounted the master cylinder under the battery. All that is left is lengthening the speedometer and tach cables, lengthening the throttle and clutch cables, hooking up cables to the m/c and making linkages to the shifter. That will be done in the spring when I can find the frame in the snow!!!
Offline thehammer
Re: CB550 or CB650?
« Reply #9 on: February 13, 2011, 09:15:36 AM »
ya, i would not recommend dismantling the rack of a set of cv carbs, or working on them at all for that matter. solely because of the vacuum Ts that run from carbs 1-2-airbox and 3-4-airbox. such a chore to assemble. also the way the linkages are put together in the middle just boggles my puny mind.
Offline wardenerd
  • '77 550F '81 650C
Re: CB550 or CB650?
« Reply #10 on: February 14, 2011, 08:22:23 AM »
I have a 77 550F and an 81 650C.  I would think the 550 would be a better candidate than the 650 because of how they look stock.  The 650 is considerably more powerful than the 550 but I would think the nimbleness of the 550 again make it a better candidate.
Offline Doggie
Re: CB550 or CB650?
« Reply #11 on: February 14, 2011, 04:14:51 PM »
Seems like all the folks here agree that the 550 would be the best way to go for a Cafe Racer. Looking forward to starting it after I finish the dragbike. Watching the new show on TV and getting the mag has made
me more determined to get going....
                                                              Doug
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: CB550 or CB650?
« Reply #12 on: February 14, 2011, 04:19:15 PM »
Put my vote on the 550 too, and not just because I cafe'd a 550.
Cheers
FJ
