Author Topic: 15mm X 60mm piston pin  (Read 5765 times)
Offline turboguzzi
« on: March 01, 2011, 10:31:51 AM »
Not really liking the quality of the 15mm piston pins in the wiseco kit i got, neither the fact that they have a 3mm wall thickness, hence really heavy.
As I've learned to appreciate the quality of original honda piston pins (and their convenient price :) ), is there any honda model out there that has a 15mm diameter X 60mm (or longer) piston pins?
Have mounted the ones supplied by wiseco already but will be happy to swap them ASAP with something lighter
TG
Offline mec
Re: 15mm X 60mm piston pin
« Reply #1 on: March 01, 2011, 11:29:20 AM »
eventually yoshimura 812ccm (bore 64mm) pins are good for you. tapered and lightweight.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
« Reply #2 on: March 01, 2011, 02:39:35 PM »
mec
I agree...they were very nice pins.
Offline turboguzzi
« Reply #3 on: March 01, 2011, 03:21:30 PM »
Cool, where do i find them?
BTW, my cylinder bore is 69mm, the PIN LENGTH has to be 60mm.... Would the 64mm Yosh pistons have a 60mm pin then?  ::)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: March 01, 2011, 04:45:12 PM »
Would like to know too.
« Reply #5 on: March 01, 2011, 05:37:58 PM »
Several guys told me about those Yosh pins, but I think they are unobtanium. I looked a long time for lightweight tapered pins and couldn't find any the length I needed.
I don't have a CB450/500 piston but try to find the length of that one. The CB350 twin piston is 64mm, but the pin is 56mm, CB750 is 53, CBX1000 is 51mm.
Maybe you'll need to taper some new Wiseco pins. I used the 3mm walled CBX1000 pins and shaved them from 44.4gm's down to 38.2.
You might also check CP Pistons, they had several options for pins.
Good Luck.
« Reply #6 on: March 01, 2011, 05:50:48 PM »
 I'd guess Japan......about 30 to 35 years ago. Seriously..... Yosh has ties with so many Japanese OEM part manufacturers that who knows who made them. ???
Offline BLUE71TURBO
« Reply #7 on: March 01, 2011, 07:23:45 PM »
How about asking Big Jay at A.P.E. ?     ;D..............http://aperaceparts.com/wristpins.html
        15mm x what ever length you want.   ;)  ;D
« Last Edit: March 01, 2011, 07:27:33 PM by BLUE71TURBO »
Offline Big Jay
    • CBRzone
« Reply #8 on: March 02, 2011, 01:21:31 PM »
Wiseco does not list a 15 X 60 mm pin. There Honda kits come with a 56 mm long pin. We have a tool steel replacement for those.
Did your pistons come from Wiseco with a 60 mm pin?
Jay
« Reply #9 on: March 02, 2011, 01:52:46 PM »
Jay
  That pin is a straight wall design....right?
Offline turboguzzi
« Reply #10 on: March 02, 2011, 03:18:57 PM »
Jay
hi jay
just as i was planning to write you...
it's the kawasaki 69mm 810 kit, the pins there are 60mm.
the pins that came with it are straight wall and pretty heavy
the reason i posted this here in sohc was to check if there was any stock honda 15mm pin of such length (or more, it's easy to shorten) as from my experience, the stock honda pins have been better quality than the ones  i got with all sorts of aftermarket pistons.
but having one of your tool steel pins could be another option
TG
« Reply #11 on: March 02, 2011, 07:33:18 PM »
 Man it is sooooooooo easy to taper them before heat treat and grinding.. should not be too difficult  for someone to make them...
Offline Big Jay
    • CBRzone
« Reply #12 on: March 03, 2011, 05:36:31 PM »
You are correct S526 pins. We never made a pin for that as no one ever made enough power with the NA 810 to need a tool steel pin, and the turbos are 16 mm.
Offline Big Jay
    • CBRzone
« Reply #13 on: March 03, 2011, 05:38:05 PM »
I'll bet someone could pull that off, 4 pins, for probably less than $100 each.  ;D
Offline turboguzzi
« Reply #14 on: March 07, 2011, 08:32:12 AM »
Thanks Jay
OK then, long story short, I need such pins :)
Straight wall will do.
Check your personal messages...
TG
