Author Topic: Carb sync done...now starter doesn't work  (Read 1131 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: March 30, 2011, 12:08:44 PM »
These are not related, just feeling 1 step forward, 2 steps back.
I have no problem when I kick start the bike. Turns over first kick, no sweat. But the starter button does nothing. I checked fuses (blade type), they all look good, and I didn't think this would effect it anyway.
Any ideas of where first to check?  I was in the headlight bucket a while ago, but I'm pretty sure that the electric start worked after that.
Just fishing for places to start.
Thanks in advance.
Scott
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: Carb sync done...now starter doesn't work
« Reply #1 on: March 30, 2011, 12:11:35 PM »
Check your starter relay, on the electrical panel.
Bikes parked out front mean good chicken-fried steak inside.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: March 30, 2011, 12:13:38 PM »
Thanks. What would I be looking for? Connections?
~Sophocles
Offline Silverback
« Reply #3 on: March 30, 2011, 12:21:51 PM »
Is it making noises when you hit the button? Clicking usually indicates low battery charge or relay. No sound usually indicates extremely low battery or switch issues. You can check the switch by testing continuity on the starter switch connector in the headlight bucket. Put leads on yellow/red and black. These should have continuity when the button is pushed. If no continuity, you have the common broken/dirty starter switch issue.
« Last Edit: March 30, 2011, 12:24:43 PM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: March 30, 2011, 12:41:54 PM »
No noises, forgot to mention that in OP. Sorry about that.
I will test that when I get home. Battery was out for a few cold days. I'll test, and bring battery in for a fresh up.
Thanks.
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: March 30, 2011, 01:01:35 PM »
My bike did that once it turned out to the starter solenoid. You can take it apart and clean it. There are posts on here about that. Mine has worked since.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #6 on: March 30, 2011, 01:14:47 PM »
First verify that the start works.
Bridge the tow big posts on the solenoid together:  big sparks and and the starter motor should spin.
Then verify that the starter solenoid works.
There are two small wires on the solenoid apply power across these should engage the solenoid and the starter.
There are two wire Y/R and Gr/R.  Gr/R is ground when the trans is in neutral or the clutch is pulled in.
Y/R is +12 when the the stater button is pushed in.  If the solenoid is good, then one of these is missing (pwr or GND), and you have to track the path to find the omission.
Gotta say.  The bar switch is most likely crumbled.  But, maybe you are lucky to have something else go awry.
Offline nhodges
« Reply #7 on: March 30, 2011, 01:15:20 PM »
+1 on checking the continuity of the starter button.  Thats what was wrong with mine.
good luck
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #8 on: March 30, 2011, 01:44:24 PM »
I'll check the switch as soon as I get home. Then off to the next checks.
Thanks guys.
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #9 on: March 31, 2011, 09:34:55 AM »
Sorry to have waste your time folks. I threw the battery on the tender overnight, and the starter worked instantly after I got the battery back on the bike.
I had always heard a clicking in the past if it was really low. This time I guess it was so low it didn't even do that, which is why I posted.
At least I will know the procedures now for when te starter button does turn to dust :)
Thanks for all the input.
Scott
~Sophocles
bollingball
« Reply #10 on: March 31, 2011, 09:47:48 AM »
Now find out why your battery is low.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #11 on: March 31, 2011, 11:49:56 AM »
I think it may have been a bunch of low RPM riding, few really cold days without running, and then me doing carb sync - first time, idling for quite a while.
I'm looking at new batteries soon. This one does ok if I charge her up pretty regular, but hauling it inside to te tender is a pain, so I get lazy about it. Hopefully now that the weather is better, I can hope for a decent stretch without having to stress it.
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: March 31, 2011, 12:37:45 PM »
How old is it? Did it come with the bike?
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #13 on: March 31, 2011, 01:12:15 PM »
It did cone with the bike, but the PO assured me it was te bestest, greatestest, most loving battery of all time :)
Actually, it was new, and I tested it with one of those ball float testers a while ago, and it seemed fine. I've tested it with multimeter as well, and it is usually pretty good (within specs found here on the forum). But it has given me enough issue this very cold winter to want to start fresh.
But there is snow on the way AGAIN tonight!!!  I will, wait for the Spring weather before dropping any cash on a new one.
~Sophocles
