Author Topic: Assembling my '74 CB550 - Putting it all back together  (Read 176519 times)
Offline MIKE550/4
Re: Assembling my '74 CB550 - Electrical System Pt1 - Rear Fender/Tail Lights
« Reply #200 on: February 06, 2014, 10:53:36 AM »
a great thread and story
restoring a 78 cb550k3 myself and been really helpful
might even start a thread of my own but would be pale next to this one
thanks for sharing the info
heres my dilemma I went powdercoat on frame and now having find out I have to earth the bike finding removing powder a job, so can see why you painted
Offline SohRon
« Reply #201 on: February 06, 2014, 04:50:32 PM »
Now I feel bad about joking about the sticker in the first place - seems I opened a can of worms.
I'm sure you meant well...   ::)
 ;D
Really don't think you had much to do with the present discussion. I think we just had an honest misunderstanding that turned into an opportunity for everyone to learn a bit more about the bikes. I know I did...
Actually, I did powdercoat both the frame and swingarm. I used a rasp and file to get rid of the PC for grounding purposes. Check out page one of the thread to see what I did to ensure a good chassis ground.
VERY CAREFULLY use acetone on a rag and wet the area to be removed. Then use a razor blade to lift off the powder coat
Interesting! I'll have to give it a try when I go to install the main harness. I need to remove some PC in the coil mount area for a harness ground, so I'll give it a shot!   ;D
Thanks for the comments, guys!
Offline sourjon
« Reply #202 on: February 16, 2014, 01:33:07 AM »
Wow what a thread. I just purchased a basket case 71 CB500, registered with SOHC4 looking for build threads and stumbled across this. It's going to be a great resource for getting mine back together. It too has a tweaked frame that I didn't discover until I got it home and started doing a much closer inspection. There's a nasty scar on the points cover (at least that's what I think it is--left side of engine)and left side rear down tube like they've been hit. Just behind the neck the top tube has a wrinkle on the left side that isn't there on the right leading me to believe the whole frame is tweaked slightly concave. Don't trust it. I only paid $300 for the whole thing and it has good compression and is pretty complete (including the carb bank) so I'm not too disappointed. Found a frame and engine auction on ebay and won it yesterday for $100. Just got to go pick it up. Can't wait to get started.
Thanks for taking the time to write all this up with such great pics.
John
« Last Edit: February 16, 2014, 02:42:11 AM by sourjon »
hank3841
« Reply #203 on: February 16, 2014, 02:11:54 PM »
Bravo SohRon for the integrity to stick to your guns. Get well so we can all fix something else on our own bikes with your patient guidance. Thanks again.
Hank
Offline sourjon
« Reply #204 on: February 16, 2014, 02:51:19 PM »
Welcome. Points cover is on right side; left side is stator and field coil. Check over very carefully your steering stem, trees and fork tubes. If their is I evidence of a blow to the frame, these items will also be suspect.
Oh yeah it's toast and I wouldn't trust it t ever be true. I picked up a good one and a spare motor from ebay today for $100 for both. I was the only bidder and it was close enough to drive and pick it up.
John
Offline Mattzilla
loving this!
Offline MickB
SohRon your build has made me re-evaluate my build and in some cases go back and redo them properly rather than "near enough is good enough"
Also I've decided to restore the motor before doing the rest after seeing your build. I've almost finished my front and back ends.
Offline SohRon
Mick, Hank, Sourjon, et al; thanks for the kind words, and it's good to know that the thread has been an inspiration! I'm always happy to hear that it's been of value to someone - makes it worth the effort!
I've actually been making progress on the bike and hope to post the 2nd half of the electrical sometime soon. I absolutely, positively, one hundred percent have to finish the build this year for bunches of reasons, some of them being that this is the 40th anniversary of the introduction of the CB550 and I'd like the bike to be finished for that, plus I've acquired a '65 Corvair that I need the garage space for and need to turn my attention to... it'll be 50 years old next year, and that's another special anniversary (not to mention the work I'm doing on the VW Bug that I'd like to get out of the way). So there's a lot on my plate for this summer, with the bike build leading the way.
With that in mind, I've started work on the tank and side covers. Last weekend I girded my gonads and de-rusted the tank I intend to use for the build. I used "Prep and Etch" full strength and let it sit for a couple of hours, turning the tank every fifteen minutes or so, and it did a fantastic job. Granted, the tank wasn't that rusty to begin with (sorry... no before and after pics!), but it was bad enough that cleaning was necessary. After draining the acid, I washed it out good with the hose then hit it with a blast of compressed air,  followed by a heat gun 'til the tank was too hot to handle, then let it cool and finished it up with a wash of acetone. I then blew the tank out again  followed with another blast from the heat gun. After a week the tank still looks good without a trace of flash rust, so I believe it's good to go.
Here's the tank as it sits today (yes, that's a sock in the filler hole!)
This pic also demonstrates why you don't want to attempt this with a painted tank; you can clearly see what the acid did to the paint...
I've decided to finish the bike with "Flake Sunrise Orange" as it seems to be the most iconic color for these bikes. The real bummer is that the tank was originally Sunrise Orange, but someone felt the need to cover it with this butt ugly brown color (what were they thinking)! Unfortunately, there are enough scratches and dings on the tank that I would have had to repaint it even if the PO hadn't covered the orange .
So that's where things are now. I should be finishing up the electrical stuff soon, which leaves only the tank and covers to complete the build. Pretty exciting stuff, eh? Thanks to all who have provided insight and encouragement for the project. Couldn't have done it without you!
Now... if I can only find someone to do the paint work...
« Last Edit: May 06, 2014, 07:10:46 PM by SohRon »
Offline MickB
I've got a tank under the house and a POR tank restore kit, I'll get to it over the next month or so. I reckon it'll be another 12 months or so. I'm still to get an exhaust system (a proper 4 into 4), been quoted $2500 in Oz (most expensive country in the world), so I'll keep an eye in eBay.
The corvair will take some time, send it to Chip Foose.
Offline Lostboy Steve
Where can I follow your Corvair Build? After seeing this, and having always wanted a vair, would love to see what you're up to there.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline SohRon
Sorry, no project thread for the 'Vair. It is a '65 Corsa that belonged to my uncle who started rebuilding it then lost interest when other priorities intervened. He's already rebuilt the engine and turbo (wahoo!) and has the body in primer, so I'll be left finishing that up as well as restoring the interior. The nice bit (besides already having rebuilt the engine) is that he's selling it to me for the money he's already put into it, so I'm getting a great deal. Right now it's still out on in his barn until I can create space for it at my place, which is one reason that I have to finish up the bike.
Doing a thread like this one is very time consuming, what with taking dozens of photos of each step and then reworking the best of the lot for posting... I could have had the bike done years ago if all I'd done was restore and assemble it without the detailed pics and write-ups. Don't get me wrong; I've enjoyed creating the thread as it is and don't regret a bit of it, but I doubt I'll do another. I could just imagine how long it would take to do one on something as complicated as a car...
Anyway, thanks for the interest... I'll post some pics when I actually have it in my possession!  ;D
« Last Edit: May 08, 2014, 11:50:29 AM by SohRon »
Offline Gman
SohRon,
Good to see you back at it (or at least telling us what you've been up to since the last posts).  We're pulling for you to get 'er done in time for the 40th!  Anything I can do, let me know.
Oh, and when you get the tank done, make sure the decals are straight.   ;D ;D ;D
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline SohRon
Re: Assembling my '74 CB550 - Electrical System Pt2 - Peripherals
« Reply #212 on: July 13, 2014, 12:47:16 PM »
Sorry that this update comes so late, but there's been a lot going on behind the scenes relating to the build that will come into play in the next couple of posts. I'm hoping to get the bike finished in the next few weeks and have been doing a lot of work aimed toward that goal, so let's keep our fingers crossed that will happen.
There's a lot still to cover regarding the electrical installation; in fact, it looks like it will require a couple of more sessions to complete. I'll begin by fitting some of the peripheral components, then move on to installing the main wiring harness and getting everything to work in the next post.
Time to get down to business! Here are some of the items I'll be including in the next couple of posts - I may or may not get to all of them now, but we can at least take a look...
At upper right we have the coils; to the left of that is the electrical panel assembly. Directly below that is the right rear upper engine hanger bracket (whew!) with its mounting bolt and washer. To the left of the hanger is the positive battery cable, followed by the battery box (with mounting bolts), the negative battery cable and, finally, the rear brake switch with spring.
In addition I'll be installing some of the following today
At top are the headlight bucket and the headlight itself, along with its wiring harness and mounting hardware. Below and left is the main (ignition) switch. then the turn signal buzzer. Moving right we find the horn with mounting bolts and tach cable guide and, finally, the front turn signal assemblies.
As I said, I'll probably not get to all of this in this post, but rest assured that I'll get around to everything eventually.
To begin today's build, I installed the battery box. I sandblasted the old one then painted it up with POR 15 Chassis Coat (now POR-15 TOPCOAT "Chassis Black") which matches the original semi-flat finish. Here it is after painting with all of its little parts displayed
The mounting rubber and "collars" (small metal tubes) are in good used condition from an ebay "Box-O-Bolts" auction. This next shot shows the assembled box with its mounting hardware and associated components. To the right of the box is the battery retaining band; directly below that is the negative battery lead. Then we have three mounting bolts: 1 8X100 bolt (with split washer, washer and nut); 1 8X65 bolt with washer; and 1 8X40 bolt with washer. To the left, completing the list, is our old friend the right rear upper engine hanger bracket. I've tossed that thing on and then ripped it off a couple of times before, but now is the real time to mount it. If I ever edit this build thread, I'll probably remove any mention of it 'til this step as it really isn't needed at any other time than now...
I started off by fitting the engine hanger bracket. It's installed from the rear of the downtube, the central hole fitting over the upper rear engine hanger bolt which extends from the engine; the bracket is loosely held in place with the 8X40 bolt which extends through the frame mounting lug into a nut that's been welded to the rear of the bracket
One thing to mention about the above pic is something we've discussed before, but bears repeating: All of the frame mounts here have been sanded down to bare metal front and back, and the engine has been relieved of paint as well, so that a good ground connection exists between the frame and engine. All of the exposed metal has been coated with dielectric grease in an effort to cut down on corrosion at these connections.
I then mounted the battery box into its spot in the frame. There are a pair of brackets welded onto the upper frame rail (below inset)...
...that the upper left "arm" of the battery box fits into. The 8X65 bolt (with washer) is inserted through the frame bracket, then through the "collar" that runs through the battery box mount, and into the rear bracket where it's attached via a nut welded onto the back of the bracket.
There's another mount on the lower right corner of the box, and it fits up against the hanger bracket, sandwiching the hanger between the battery box mount and the frame rail. The 8X100 bolt is used to attach the box; after running through the frame and box mounts it's affixed from the rear using a nut, split washer and an 18mm washer (inset below)
Installation of the battery box is completed by attaching the negative battery lead at the upper rear hanger bolt using a nut and split washer. Once the nut is torqued down, the cable is routed up into the box, ready for use.
Next peripheral to consider is the Electrical panel. I picked this up with a used wiring harness several years age on ebay. Don't know what caused the green corrosion you can see on the connectors - it's hard to say
I used good ol' fashioned brass cleaner and skinny files on them and they came out nicely with just some mild pitting. I stripped the panel completely down, sandblasted and repainted the carrier, then spent a relaxing afternoon refurbishing the wiring harness and all of the other little parts that make up one of these panels
Here's the finished panel. Front
and back
It fits into an opening provided on the left side of the frame using two each 10mm bolts and 18mm washers (inset below)
and, until I install the wiring harness, that's all she wrote on that...
Moving on, the next components to consider are the coils. Here they are with their mounting hardware: two 10mm bolts with nuts and washers, and two wiring clamps
As you can see, the coils are connected to each other by front and rear carriers that fit into the frame. The wiring clamps are attached at the breather cover and help route the wires for cylinders one and four; I'll get back to those in a bit. Installation of the coils is fairly straight forward. Both the wiring harness and coils are grounded to the frame via the front coil mounting bolt. Honda originally provided the ground path by leaving part of the frame bare at the coil mount; it looks to me like they just slapped some tape over the mounting lug before painting the frame. Here's a shot of the mount prior to refinishing the frame, showing the original ground relief (below left - this occurs only on the front left portion of the frame mount)
On the right, I've scraped away the powdercoat, emulating the original relief. The area of relief is slightly different on mine; in an effort to keep this bare patch as minimal as possible (Honda couldn't have cared less) I used the coil mount held up to the frame to delineate the actual mount contact area. I can always remove more powdercoat if it turns out to be necessary...
...and, of course, I'll smear some dielectric grease on this exposed metal before actually mounting the coils.
The coils are fitted to the left side of the frame utilizing the two 10mm bolts, nuts and washers, with coil 2&3 on the left and 1&4 on the right
The front bolt has been only temporarily fitted; I'll need to use it later to attach the main harness ground wire. I've fully installed the rear bolt, however; additionally, I've routed the HT wires to their respective cylinders, with the wires for #1 and #3 crisscrossing each other through the frame opening.
Now, here is where those little wiring support clamps come into use
The wires for #s 1 and 4 cylinders run back over the top of the engine before being directed toward each respective spark plug. I don't know why Honda did it this way... maybe to keep the wires away from the heat of the pipes... I just don't know - but this is how Honda's engineers decided it should go, so that's why we're doing it here. The little supports are attached via the two outermost bolts on either side of the breather cover and the wire is run through (below left)...
Click on pic to expand
...then the clamp is bent up over the mounting bolt, keeping the wire securely in place (above right). This acts to lift the HT wire so that it isn't lying directly on top of the engine. Here's a view from the top, showing how the wires are routed (#1 cylinder on the left)
With the coils in position, the next item on the agenda is the Main switch. Here it is with its related housing (aka "cover" or "Main Switch Bracket"): bolt, washer and mounting nut with washer
There's a little bracket welded to the left front down tube. The housing is positioned onto the rear side of this bracket via a "lip" formed on the backside of the housing (inset below) that fits into a slot on the bracket
The 10mm bolt and washer are then inserted from behind through a hole in the bracket into the housing where a nut has been welded into position to accept the bolt
The switch itself is then inserted into the cover from behind, and the big washer and nut are run up to hold it in place. There's a slot in the switch body that corresponds to a pin stamped into the housing face, orienting the switch into the proper position, so there's no chance of getting the it in wrong
I'd like to take a moment to give yet another thumbs up for POR-15 BlackCote (now POR-15 TOPCOAT "Gloss Black"). I painted these parts 3-4 years ago in a painting marathon one weekend at work, then transported them all back home in my old Summit wagon. Unbeknownst to me, this little cover slipped out out of sight and disappeared into the far recesses of the Summit's interior. I used the Summit as a work car and generally treated it like a pickup - we hauled sheetrock, paint supplies, trash and various other sundry items in the back of it. It was a nice little machine that came out about 20 years ahead of its time...
The upshot of the story is that when the tranny went on the Summit I decided it was time to part with it (one of the worst mistakes of my life... I loved that little PTV). While cleaning it out for the last time I came across the ignition switch housing packed down with all of the mud, crud and debris in the back of the car. It was covered in dirt, leaves, sand, fur and who knows what else; one look at it and I knew for sure it would have to be stripped and repainted. It looked like something that had dropped out of the south end of a northbound ungulate, then rolled in dirt and used as a kickball. I was sure it was a gonner.
I took it inside and ran some hot water over it and, lo and behold, to my amazement it came out looking much as it had the day I painted it. There were a few minor abrasions in the paint, but otherwise it was as good as new. It made me wish I had taken a before picture just to show the difference, but I had been absolutely certain that there was no way it could have survived its ordeal and I didn't bother. Wish I had, now. Turned out there was no need for repaint, and I'm using it just as I found it after cleaning.
POR-15 TOPCOAT... Tough stuff!
Moving on toward the front of the bike, the next order of business is this little item: The Dreaded Turn Signal Buzzer. Those who know how me will be surprised to see this here; it came with the bike when new, so it must be included in the build, whatever my personal feelings toward it may be...
It makes a racket that corresponds to the turn signals, reminding you and everyone else within three square miles that you have the turn signals on. For an idea as to how it sounds, picture the most annoying short-duration noise you can think of, then imagine it repeating itself over and over and over again as you sit in the middle of a sweltering traffic jam. Imagine drivers in neighboring cars starting to stare at you as you sit there with the sweat pouring down your back; and kids start crying and one little girl starts screaming "Momma, Momma! Make it stop!!!... and her mother, already driven half berserk by the din and the heat, turns around to shut the kid up and her foot slips off the brake onto the accelerator, sending her Hummer careening into a utility pole that collapses onto a gasoline truck refilling the tanks at a neighborhood Piggly-Wiggly; with the resulting fireball traveling three city blocks up the sewer system where it ignites and explodes a hidden pocket of natural gas that decimates an entire strip mall and sends a thirteen-story insurance building rocketing 1,473 feet into the sky before crashing back down to earth... in the middle of a poodle farm...
But, I digress... sorta
Seriously, though, I do have some objections to this buzzer. If you're driving defensively you won't need it; if you're paying attention to what you're doing while driving, then that light won't stay on for long. However, if you believe you have more important things to think about other than maintaining an awareness of your surroundings while riding a motorcycle then, yes... keep the buzzer.
It fits into this bracket attached to the inside of the left headlight "ear"
There's a square mount that fits into the hole in the bracket, and the "speaker" is oriented back toward the driver
The wire is then routed down through this wiring clip welded to the inside of the "ear"
For our final installation of the session (drum roll, please) we move to the front of the bike to the horn. I'll fit it using two bolts with washers, and I'll be installing the tach cable guide as well (the curvy wire thingie in the center bottom)
The horn mount sits out in front of the frame...
...and the horn is installed using the bolts and washers. The cable guide is entrapped behind the left bolt, fixing it in place
And, with installation of the horn I'll call this post complete. Next session will cover fitting the main wiring harness, the front blinkers and, yes, installing the throttle cables.
'til next time
« Last Edit: December 19, 2014, 04:16:35 PM by SohRon »
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #213 on: July 13, 2014, 01:02:33 PM »
So THAT is where it goes!
Offline flatlander
« Reply #214 on: July 13, 2014, 01:33:20 PM »
just came across this awesome thread. sohron, your work here is amazing and the way you document it, is really valuable. it should be made into a book or at least a PDF for download.
Offline KAgin
« Reply #215 on: July 13, 2014, 02:32:11 PM »
SohRon I am glad you are back.  My build had stalled because I had done everything in your thread and I was lost on what to do next.
1975 CB550K
1976 CB750K
Offline Bootsey
« Reply #216 on: July 13, 2014, 04:41:30 PM »
Brilliant thread, that I sincerely hope sticks around, as it's a much appreciated source of vital info and inspiration!
Offline SohRon
« Reply #217 on: July 13, 2014, 07:21:31 PM »
Thanks for all of the kind replies and, once again, I'm happy the thread is turning out to be useful. I'm looking forward to completing the bike this summer, so there'll be more to come soon!
Frankenstuff, that's the subtitle of the thread!  ;D
Offline Gman
« Reply #218 on: July 13, 2014, 07:39:13 PM »
Aaaaayyyy - missed you!  Glad to see you posting and good luck the next few weeks trying to wrap it up.
G
'76 CB550K
« Reply #219 on: July 14, 2014, 02:48:17 PM »
Thanks for the update SohRon!  Great stuff as always.  Love the buzzer fantasy bit...funny stuff...
Offline Tews19
  • I am no
« Reply #220 on: July 14, 2014, 05:41:10 PM »
Your attention to detail and photography skills are second to none! Keep the updates coming please!
1970 Honda CB750 survivor.
« Reply #221 on: July 14, 2014, 06:06:30 PM »
Ok, Ok guys....ease up. All of this praise will go to his head and then SohRon will lose his focus.
Offline MickB
« Reply #222 on: July 15, 2014, 04:02:35 AM »
Sohron I liked your tip on buying bolts on eBay and what to look out for, really helped me.
That gem was hidden and could be easily missed.
Regards
Offline Tews19
  • I am no
« Reply #223 on: July 15, 2014, 04:04:17 AM »
I missed the tip mick. May you share?
Offline albertaboy
  • No way I'm a
« Reply #224 on: July 15, 2014, 04:16:18 AM »
I just found this build thread and one word. Wow!.  Great photos and great details.
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
