Author Topic: Cam chain tensioner problem  (Read 1152 times)
Offline clintinga
« on: April 11, 2006, 12:22:55 AM »
Hey Guys,
I am in the process of getting my 76 750F back together and I wanted to adjust the cam chain tension.  So I followed the directions in my shop manual but their is a problem.  The mark on the spark advance that is supposed to be 15 degrees behind the F or T mark (don't have the manual in front of me so I don't remember which mark) is not there.  Just to clarify, their is no mark after the F and T to
rotate to to set the cam chain tension.  So??? Is this an aftermarket part? or one from a different model????  Is this year or F specific?  I want to adjust the tension but also want to make sure I have the right parts to begin with.  Many thanks in advance for the help I will recieve with this.
Thanks,
Clint
Offline Bob Wessner
  • "Carbs Suck!"
Re: Cam chain tensioner problem
« Reply #1 on: April 11, 2006, 02:06:21 AM »
There really is not separate "mark," but rather you use the spring post as a reference point. Check this posting out. Open/print the instructions that Jonesy attached. Good luck.
http://www.sohc4.us/forums/index.php?topic=1977.msg14550#msg14550
Offline Jonesy
  • Shop Rat
« Reply #2 on: April 11, 2006, 05:09:06 AM »
Thanks, Bob- You beat me to it!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: April 11, 2006, 05:13:45 AM »
You need a 13 yr old basset hound that needs to go out in the wee hours.  ;D
Offline clintinga
« Reply #4 on: April 11, 2006, 09:26:57 AM »
Thanks Bob!!!
Clint
