Author Topic: 76 cb550 F  (Read 2330 times)
Offline zedteamk2
76 cb550 F
« on: April 26, 2011, 06:47:13 PM »
So, i was given a 76 cb550 f.
So far i've cleaned the carbs, and changed the oil and spark plugs
I received a throttle and switches in the mail today and attempted to hook them up.  I think either i got the wiring hooked up wrong or the start switch is busted.
I'm confused with the 2 black wires coming from the throttle, and the one black and one green one coming from the bike  I've matched the others up with their corresponding colors.
I need to replace the starter switch first, but if anyone can clarify which wire goes where i'd appreciate it.
On the place side, i figured out how to get the starter to turn over... and it did :).
I'll post some pictures soon.
Thanks
76 Cb550f and a 82 Yamaha Vision
Offline zedteamk2
Re: 76 cb550 F
« Reply #1 on: April 28, 2011, 05:47:04 PM »
Well, the gas tank has a small hole on the side, so i have to fix that before i can get gas into the engine and see if it starts up.
The starter switch imploded.  I got a switch from radioshack for a couple of $ and have fixed that problem.
There is a large auto/motorcycle swap meet near me this weekend.  I'm hoping i might find some parts there.
Re: 76 cb550 F
« Reply #2 on: April 28, 2011, 05:59:18 PM »
First off, welcome from Lake Travis! I have a 550F too, replaced my starter switch last year (common issue).
I'd consider getting another tank if yours is rusted, pretty easy to find.
Good luck.
Offline CBGhia
Re: 76 cb550 F
« Reply #3 on: April 28, 2011, 08:04:21 PM »
Another Texas 550f.  My starter switch was bad too.  I have controls from a 72 500 on there, but no starter button. Kick start only in my house : )
Offline zedteamk2
Re: 76 cb550 F
« Reply #4 on: May 07, 2011, 03:39:30 PM »
I did find another tank.  Unfortunately the petcock i have doesn't fit :(.
The one that was on my bike is too large.
The tank i got is supposedly from a 77 supersport (it's green and says supersport on it ).
I'm going to do some digging around to see if i can find an appropriate petcock.
Re: 76 cb550 F
« Reply #5 on: May 07, 2011, 05:27:28 PM »
Yeah, pretty sure they changed 'em in 77
Offline zedteamk2
Re: 76 cb550 F
« Reply #6 on: May 08, 2011, 06:55:02 PM »
I found an adapter at the local hardware store.  Unfortunately it made it sit too low.
I'm hoping i can find a lower profile one.
The $4 option almost worked...  :-[
Offline AndrewCola
Re: 76 cb550 F
« Reply #7 on: May 09, 2011, 09:29:42 PM »
i just bought a 76 cb550, so i'll be interested to see what you do with yours
the many lives of Casey Jones
AFM
Re: 76 cb550 F
« Reply #8 on: May 11, 2011, 05:11:41 PM »
Another new member with another '76 CB550F. My starter works though, which is nice. I'll be watching this thread closely. :)
Offline Bankerdanny
  • Endeavor to persevere
Re: 76 cb550 F
« Reply #9 on: May 11, 2011, 05:23:03 PM »
The correct petcock is available new for under $50 including shipping. I would just order one (in fact I did for my 77 550k)
Offline zedteamk2
Re: 76 cb550 F
« Reply #10 on: May 14, 2011, 05:00:37 PM »
Banker, are you referring to the petcocks on ebay ?
Offline zedteamk2
Re: 76 cb550 F
« Reply #11 on: May 22, 2011, 03:26:54 PM »
I got a petcock off ebay for $25 shipped.  It was a for 77 cb750.  Works great.
I tried to start her up, but with no luck.
I ran out of time today, but next time i'm going to go out and start trouble shooting.
I know it's getting air, it looks like it is getting gas, so I'm going to start with checking if it is getting spark.
Re: 76 cb550 F
« Reply #12 on: May 27, 2011, 05:15:11 PM »
Make sure your battery is fully charged. Then pull a spark plug, connect it to plug wire, lay against cyl head and crank it. You should have a nice blue spark.
Offline zedteamk2
Re: 76 cb550 F
« Reply #13 on: May 30, 2011, 08:19:47 AM »
That my goal for today.  I also need to make sure the headlight is switched off. I had to replace the starter switch, so i will need to do that manually.  I'm going to dig around the forums for a description of the wiring
Offline zedteamk2
Re: 76 cb550 F
« Reply #14 on: May 30, 2011, 11:35:33 AM »
Yep, no spark.
So far i have tested the Run/Off switch, it works.
I wonder if i have the wiring correct going from the controls to the rest of the bike.
I matched the colors on all of them, except i have 2 black wires coming from the switch, and if i plug them both into the black coming from the bike, i have a left over green coming from the bike.  I have tried putting black to green and no change.
I did find out something that is bugging me.  Behind the fuse block and starter solenoid there is a green wire with no home.  It's very short and has a right angled female connector on the end.  I cant find anywhere for it to go !.  Any suggestions?
Also, any suggestions on how to proceed.  Ugh, i hate electrical work
Re: 76 cb550 F
« Reply #15 on: May 30, 2011, 11:41:45 AM »
Green is ground on these bikes.
