Author Topic: Broken bolt mount! Help?  (Read 935 times)
Offline 70cbk0
« on: April 28, 2011, 09:08:47 AM »
When I got the bike it was missing the rear case (sprocket) cover, and a broken off bolt in the bottom mount. It's been soaking for a couple of weeks, it wouldn't budge. Heated it today, it came out alright, and busted the mount. Question. get it welded? or would JB Weld work somehow, I hear fantastic results with it, but I'm not sure about it in this area. Thoughts?
You can see the crack, I know the bottom half came loose, I'm almost wondering if the top half isn't loose too. Thanks, John
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline Grabcon
Re: Broken bolt mount! Help?
« Reply #1 on: April 28, 2011, 09:39:27 AM »
That sucks. If it were mine I would find a good heli arc weld and have them weld it up. Leave the motor together. A good welder will bevel and clean everything. Once done if needed re-drill the hole.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
« Reply #2 on: April 28, 2011, 10:24:22 AM »
If its a 750 and  you do not have to be 100% KOrrect, try this;
 I have taken the sprocket cover (spare) screw holding, they are way quicker to take on and off..
 Then fix the bad hole nicer, if the engine is out, later on.. and cut the part with the lower screw off. With the cover being a bit smaller and only 1
Offline 70cbk0
« Reply #3 on: April 28, 2011, 10:57:05 AM »
Yes, the engine is out. I poked around and 2 pieces broke off, so I'm trying JB Weld. It looks promising. I'll let you know. Thanks guys
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline wrenchmuch
« Reply #4 on: April 28, 2011, 03:44:28 PM »
I have the same break on my K1 and I just use the other bolt to hold the cover on . No problems .
CB750K1
CB750K4
Offline 70cbk0
« Reply #5 on: April 28, 2011, 08:57:10 PM »
Oh, good to know, I was afraid 1 bolt only would be game over.
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
