Author Topic: valve spring install  (Read 1519 times)
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
« on: May 03, 2011, 06:57:53 PM »
I acquired a cb550 that needs the valve springs reinstalled. Haven't investigated if I need a (motorcycle/Honda/Autozone tool) spring compressor or what to get this done.  :-[ Any advise?
CB750K6- survivor   CB500K2, CB550K2- projects
Offline nayto550
Re: valve spring install
« Reply #1 on: May 03, 2011, 07:19:18 PM »
I suppose a spring compressor built specifically for this task would be preferable.  However, I bought a cheap compressor at NAPA, then welded up a little adapter to make the reach to the spring...  I know it's not right, but it works for me!  ;)
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
  • SEE YOUR AD HERE!
« Reply #2 on: May 04, 2011, 09:34:21 PM »
Thanks nayto, that's what I was looking for...just cuz it's not what the HONDA service tech uses, doesn't make it wrong ;D
Offline Shoeboxjoe
  • Large Breasts
« Reply #3 on: May 05, 2011, 12:41:59 PM »
The Sears $20 valve spring tool works just fine also. Don't need to go overboard on this unless you're planning on doing a lot of top end rebuilds :P
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
  • SEE YOUR AD HERE!
« Reply #4 on: May 05, 2011, 08:07:07 PM »
Thanks Shoeboxjoe, yeah just want to put this one back together that the P.O. took apart for an o-ring leak & he put viton valve seals. Sears tool will not need any adapting like the NAPA example?
Your Custom Title + rating is funny, I fixed mine too ;D
« Last Edit: May 05, 2011, 08:10:07 PM by That 70s Bike »
Offline nayto550
« Reply #5 on: May 06, 2011, 06:38:01 PM »
I just looked at the one from Sears...  it's identical to the $20 one I got from NAPA.  The end that goes onto the spring cap won't reach on the 550's, the valve springs are recessed into the head too far.  I remember quite clearly buying the compressor, trying it and ended up cussing a bunch while welding the adapter  ::).  On a 750, no problem, the valve springs aren't recessed enough to be an issue.
1976 CB550F
1988 HD FLHS
