Author Topic: Good gosh almighty I got me a 70 KO !!  (Read 7734 times)
Offline dhall57
Re: Good gosh almighty I got me a 70 KO !!
« Reply #25 on: May 18, 2011, 02:37:23 AM »
No surprises when I changed the oil. Other than needing fresh clean oil everything look fine. Had to spray some penetrating oil down spark plug holes and let soak a little bit. Plugs were stubborn didn't want to come out. I was afraid I might strip something or break a plug off in the head and if that had happened that would of made for a bad day for sure :) I was lucky and it didn't, just was very carefull and easy and got them all out. Installed a new freshly charged battery and until now I wasn't 100% sure that all electrical worked but they do!! Damn this 42 year old fellow is good condition nothing is molested or rigged or destroyed by a stupid PO. Its almost like this bike has been sitting in a time capsule for all these years. One of the lst things that stuck  out like a sore thumb was the missing air box and replaced sometime through the years with pods. I didn't want to continue to run these, but what else could I do. Well I must be doing something right in this life because I found out that the PO still has the KO air box. Can you believe it!!!!!! Hopefully this kind of luck will keep happening with this bike. I will post a pic but the bars have me a little confused. They aren't KO stk bars, Johnie had made a statement from a early pic about the m/c banjo bolt being so close to the tach. Well the reason for that is not because the m/c is mounted down the bar some Johnie, it's because these bars are shorter. The m/c is mtn right up against the throttle control. These bars measure 29" and have very little rise of only about 1 1/2 to 2" My K6 bars have about a 5' rise and are 2" longer. I actually like the bars but being that short it puts the m/c and brake line in a cramped position. The HM300 pipes are the original ones I would say and great  condition for the year. The top left pipe has about a 3" narrow hole right along the seam on top and bottom. Since this isn't very bad can it repaired with something?  Here's a few pics of that and also pipe baffles are missing. More later.
« Last Edit: May 18, 2011, 07:32:43 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Markcb750
« Reply #26 on: May 18, 2011, 05:03:27 AM »
My K6 had similar holes when I got it, JB weld will hold for quite a while.
The upper pipes can have this where they are close to the lower pipes in the swing arm area, I think you would need to remove the pipe to apply the JB weld in those areas.
My experience eventually they will rot around the foot pegs...then they are scrap.
Mark
Offline Nikkisixx
« Reply #27 on: May 18, 2011, 07:06:09 AM »
JB Weld or stitch it up with a mig if that's an option.
Offline Gordon
  • 750K1, 550K2
« Reply #28 on: May 18, 2011, 07:25:18 AM »
Unfortunately, once the pipes are showing rust holes on the outside the damage is already far worse on the inside.  The chrome layer is the last to rust through, so the metal is getting very thin in a much larger area than just the size of the holes.  As has been stated, you can prolong their life somewhat with some JB weld or muffler-mender paste.
« Reply #29 on: May 18, 2011, 07:58:51 AM »
Told you to ask about the aircleaner.. usually they cant find it or just threw it out 3 years ago... cuz it had a small crack!!
.. sounds like you got a 300.00 bonus this week..
 The pipes, will not last fourever, enjoy them as long as you can, they did last a lot of years, and are good everyday runners. I think cold-wather use when they dont warm up is the worst on them..
 As four eveything still working, its not unusual, they were  built to last, thats why I still ride one..
Offline dhall57
« Reply #30 on: May 18, 2011, 08:26:15 AM »
I got a good laugh out of this. I thought I heard a potato- potato sound, but couldn't figure it out for the life of me. Now I know. Adds a some class to the old CB doesn't it. ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #31 on: May 18, 2011, 08:33:40 AM »
I've been told the K0 bars are lower. Yours may be even lower, maybe euro's or superbike bars.
Online Johnie
« Reply #32 on: May 18, 2011, 03:30:55 PM »
Maybe he has the old bars? You can still get the KO bars from Honda. At least I could 3 years ago. They are around. Super you got the air box. That would have cost a lot of money if he did not have it anymore. How is the front brakes. My KO had so much crud in the calipers a fresh bath, seal and master rebuild things were stopping great. Gosh hall....what a find there!!!
« Last Edit: May 19, 2011, 04:46:59 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dhall57
« Reply #33 on: May 18, 2011, 05:47:14 PM »
same here Johnie. Frt brake is grabbing real bad. I've got to take caliper apart and rebuild and clean. I had to do the same on my K6. Looked inside m/c and the fluid looks like crude oil. Its not pretty. Hope m/c is still good.
Your KO is super nice. I doubt mine will ever be on that level. My goal right now is just to make it safe a dependable and ride it and ride it and than ride it some more ;)
Whats some background on your 70 KO? To tell you the truth I still can't believe a KO is in my possession. Never would of thunk it possible. Like I said from the lst thread That I posted If Im dreaming don't wake me up.
« Last Edit: May 18, 2011, 06:11:22 PM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #34 on: May 18, 2011, 06:21:37 PM »
Nice find.  Time to order tires!
Offline dhall57
« Reply #35 on: May 18, 2011, 06:55:24 PM »
yeah Im making out my parts list right now. Winning the lottery would  sure help.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Online Johnie
« Reply #36 on: May 19, 2011, 04:58:52 AM »
Hall...my KO sat for 19 years when I found it under a tarp in a garage. Did the basics and she fired right up. Drove it a couple months to ensure it was good to go and the next winter which I believe was early 2007 I did the work on it. I did not dig into the motor as that is super good. Did the carb rebuild and it has been a good marriage since. I did a caliper and m/c rebuild last night and take a look at the before and after pics below. Not only will yours look like that, but the bottom of your fork tubes will look the same. Good spots for sediment to settle. I still have the OEM ball bearings in the steering head as there was no notches in mine. I just took the old bearings out and cleaned and repacked. They are good to go. I imagine someday I will put the tapered in like the K1 & K4, but for now I am fine with it. For sure have fun and ride it. Not many guys get lucky enough to find one of these. And keep sharing those pics...
Oshkosh, WI  USA
Offline dhall57
« Reply #37 on: June 12, 2011, 05:00:36 AM »
It's been almost a month 5/14/11 since my son Justin found and trailered home ( again he found this bike by just carrying on a conversation with his boss. The owner did not have it listed for sell. Again I can't say this enough, anybody on this forum newby or oldie looking for your first SOHC/4 or just looking to add to your collection. Talk to people, ask questions because if it wasn't for that it wouldn't be park in my garage right now.
Put the tank and carbs back on it today. Rebuilt the petcock hope that stops the leak. Still waiting to get the stock KO air box the PO says he has. Right now it has Uni-Filter pods on it. Don't like them, but that's what the PO had put on. Put the new baffles in the original 300 pipes. I couldn't wait any longer I hadn't heard it run in a month. Would it start? Turn fuel on, ignition switch, starter button, said a little prayer, and contact and music to my ears first try BAM it started. This KO sounds BAD TO THE BONE the 300 pipes are great. It makes my 750K6 with it's 4 to 1 Mac pipe sound whimpie. Still got more things to do to it so I didn't ride it much , but did do a few laps around the yard slowly. Got to do some clutch adjusting its not quite right. And than I smelled gas and noticed something wrong with the left fork. I stopped and turned off the gas as fast has I could. Best I could tell it was coming from either #3 or 4 carb. As for the fork in my excitement in hearing it start up and run I had forgot all about the day before taking the fork snap rings loose getting ready to start taking things apart for the new fork seals coming in this Monday. Well I don't have to struggle with getting that fork seal out it's 2 to 3" up the fork. Well that put a end to my tour around the yard, but I did let it run some on the center stand with a fan blowing to keep her cool. It would run for a little bit and not leak a bit than all of a sudden it would start again. It did this 5 or 6 times but than I tapped on 3 and 4 carb with handle end of my screwdiver. Let it idle for awhile and so far hasn't started leaking again. Hope just a stuck float because of all the handle and turning of the carbs when they were off the bike. Interesting Saturday and I love it. Hope to have it out on the Hwy next weekend :) :) here's a pic of the fork I was taking about. :-[ :-[
« Last Edit: June 12, 2011, 06:03:02 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Online Johnie
« Reply #38 on: June 12, 2011, 06:39:50 AM »
A lot of those petcocks leak from bad gaskets which are around the 2 Phillips screws that hold the petcock to the tank. Did you happen to replace those? As far as the carbs it sure sounds like the floats are sticking. The good thing is you can remedy this with the carbs on the bike. Take the float bowl off and remove the float. I used some metal polish to lightly polish the float pin in case it was sticking there. Then remove the needle seat. I used some metal polish to lightly clean the float needle and the needle seat. There was some old gas stains there that built up. Put it all back together and has been good. Let us know how you come out. Looking good there Hall...
Oshkosh, WI  USA
