Author Topic: shifter shaft seal  (Read 15979 times)
Re: shifter shaft seal
« Reply #25 on: July 29, 2015, 01:52:23 PM »
Hmm possibly, but I think the one I need is #24, form the looks of it. I just am not convinced it's the right size.
did you not order a #24 last time?  ::)
Well, i can only say that many here only trust OEM Honda parts, and if #24 was the one i needed, I wouldn't hesitate to buy it.
did you compare the honda part number of the one you bought, with the one listed on the fiche?
you need to be sure of the model/year of your bike, and buy parts for it based on Honda part numbers.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #26 on: July 29, 2015, 02:34:27 PM »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline thwrightstuff
« Reply #27 on: July 30, 2015, 08:02:00 AM »
So I looked it up and this is the one I ordered from Bike Bandit, which appears to be bigger than the one on CMS? OIL SEAL 13.8X24X 729774. I think I'm doing something wrong. This one is too small already. The inner diameter is a perfect fit, but the outer diameter is too small and I had to use copper gasket to install it and make it seat. Advice?
http://www.bikebandit.com/oem-parts/detail/honda/91202-kfl-841/b729774
I know more than you, except if you know more than me.
« Reply #28 on: July 30, 2015, 08:05:05 AM »
Call me stupid, because I'm being very stupid right now (I swear I'm not normally this slow), but what are the units of measure (mm)? and which measurement is each number referring to? I must be doing something wrong here.
« Last Edit: July 30, 2015, 08:07:28 AM by thwrightstuff »
« Reply #29 on: July 30, 2015, 08:42:53 AM »
Measured in mm, as this is a metric bike
               ID x OD x Height(thickness)
Bike bandit  13.5 x 24 x ?
HONDA   12.5 x 25 x 8
The one you ordered from bike bandit is too big in the middle, and too small in total diameter, and doesnt even list a thickness.
Order HONDA only.  Use CMSNL link i sent you above to find the correct part numbers to order from.
Do it right or do it over ;)
« Reply #30 on: July 30, 2015, 11:06:49 AM »
Fair enough. I'd like to trust CMSNL and that diagram. It clearly says the exact make and model and year of my bike, but in the past I've come across misinformation. But if you guys all swear by it, then I can't say no. Thanks for the help doods! I'll let you know how it fits once it comes in, I'll be doing a deep carb tune and some other work this weekend.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #31 on: July 30, 2015, 12:00:27 PM »
I just use any dealer's micrfiche for the part number then google it. Partzilla has been good at the right parts as well as other online stores. Even EBAY if its in the original packaging.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline parm94
« Reply #32 on: May 24, 2016, 07:47:08 PM »
Drain ~ 400ml. I learned the hard way.
