Author Topic: Twin Piston Brake Upgrade Using OEM parts For CB750F  (Read 75474 times)
Offline Geeto67
  • A grumpy
Re: Twin Piston Brake Upgrade Using OEM parts For CB750F
« Reply #25 on: June 26, 2012, 02:53:42 PM »
I have not test fit one yet, but wonder if the latter VFR calipers would also work, the ones that are not  cast with "Honda" but are cast with a simple "cross" across the pistons.
I'll go ahead and answer this one for you right now - no. The 1986 and up VFR used a larger diameter rotor with different spacing. I have seen guys make a "cheater" plate that connects the VFR caliper to the cb fork leg but it usually is unsightly.
here is a cb900f with a VFR front wheel and caliper on cb900f forks if you can't get a visual in your head:
I think, but cannot confirm that the 1983-1985 VF750F used the same dual pistons as the 81-82 CBF but the brackets are def different.
Maintenance Matters Most
Offline jaguar
« Reply #26 on: June 26, 2012, 08:04:41 PM »
I was talking about these calipers
The castings look like they use the same mounting point, but i have no idea if they bolt in or not
Offline Geeto67
  • A grumpy
« Reply #27 on: June 26, 2012, 08:29:02 PM »
those are 1985 calipers - brake disc is the same diameter as a CBF. buy them and try them.
Offline jaguar
« Reply #28 on: June 27, 2012, 04:40:34 PM »
I just might do that the next time the toy fund is over flowing with cash
Offline Geeto67
  • A grumpy
« Reply #29 on: June 28, 2012, 03:58:36 AM »
Or you can take a cbf caliper bracket to Mitch and see if he has one you can try out on the spot.
Offline bruzer59
  • 1977 CB 750F
« Reply #30 on: July 10, 2012, 02:28:12 PM »
  I just finished my dual piston caliper up-grade on my 1977 cb 750F
Offline jaguar
« Reply #31 on: July 10, 2012, 02:30:24 PM »
Very nice
Everything went smoothly?
Offline bruzer59
  • 1977 CB 750F
« Reply #32 on: July 10, 2012, 02:32:20 PM »
  Yes it was very easy..  ~`~
« Last Edit: July 12, 2012, 04:46:40 PM by bruzer59 »
Offline jaguar
« Reply #33 on: July 10, 2012, 02:37:59 PM »
Glad to hear
Offline fastbroshi
  • Puppet
« Reply #34 on: September 14, 2012, 06:54:00 PM »
I'm actually getting parts together for this brake setup, and the one hiccup I've run across is that while the calipers seem to have been used with minimal changes if any on a lot of bikes, there seems to be only a few bikes that used that particular left hand bracket; the '81-'82 DOHC CB750F and 900F, and the '82 Goldwing.
Someone please correct me if that's incorrect.
Just call me Timmaaaaay!!!
Offline jaguar
« Reply #35 on: September 14, 2012, 08:48:40 PM »
Yes the bracket that is needed is much "harder" to find then the actual calipers.
Most of the time it is just easier to get the calipers and brackets at the same time.
But the bargain hunter type will want to piece it together and save a few bucks, at the cost of leg work
Offline bruzer59
  • 1977 CB 750F
« Reply #36 on: February 17, 2013, 09:01:07 AM »
 I JUST INSTALLED THE REAR BRAKE SYSTEM FROM A 1981 CBX 1000 ON MY 1977 CB750F
Offline jaguar
« Reply #37 on: February 17, 2013, 10:41:56 AM »
very nice.
Again everything bolted on and worked well?
Offline Roach Carver
« Reply #38 on: February 17, 2013, 11:26:53 AM »
Can anyone tell  difference with tgis upgrade. I know its subjective.
« Reply #39 on: May 20, 2013, 11:52:53 AM »
 I ordered new slingshot lines and a set of front calipers. Hopefully get to try them out in a week or two. Not really any way to definitively say they are and improvement, esp. since I am changing multiple things at one time. Two pistons has got to be better than one though right?
Offline jaguar
« Reply #40 on: May 21, 2013, 06:35:23 AM »
The "feel" is better.
Also the twin piston calipers allow you to run better pad compounds then are available for the singles.
They also look cool....
All and all its a great upgrade.
I would like to see more upgrades like this.
Simple, easy, effective and a real improvement in function.
« Reply #41 on: May 21, 2013, 11:43:43 AM »
Well, my calipers came in and the pistons are shot. So much for assembly this weekend. Where did you guys source new pistons?
Offline jaguar
« Reply #42 on: May 21, 2013, 04:42:47 PM »
There are some aftermarket replacement pistons, ill look for a link.
If not honda has them and is often cheaper then the aftermarket ones.
« Reply #43 on: May 27, 2013, 06:07:51 PM »
I bit the bullet and installed the crusty calipers. I justified the rust thinking? the pistons arent likely to go any further into the caliper until I change the pads. Anyway, long story short, I can now answer my own question that I posed earlier in the thread. There is a DEFINATE improvement over the single piston calipers. I dont know what pads I have but judging from the wear on my rotors I am guessing they have a high metal content.
If you have the later model forks then I would reccomend this upgrade.
Offline jaguar
« Reply #44 on: May 27, 2013, 07:57:46 PM »
Glad it worked well for you!
Offline garyS-NJ
« Reply #45 on: July 23, 2013, 12:30:09 PM »
regarding the rear brakes, when putting on the two piston caliper, can I use the same caliper mounting bracket (I have 78' cb750F) and same brake line?
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
« Reply #46 on: July 23, 2013, 12:39:05 PM »
Just a follow up on my previous statement. Don't be cheap. fix rusty pistons and replace the crush washers. My brakes went away on me going into a corner and I ended up in the ditch. When I get it all back together, you can be sure I will have inspected and or replaced all questionable pieces.
« Reply #47 on: July 23, 2013, 12:44:49 PM »
'82 and up GL500I (Silverwing Interstate) (the post that follows does not list the R and L bracket for the short bracket needed) and GL650 and GL650I used these same twin piston calipers and the short caliper mounting bracket needed for the F front forks. There are two variants of the caliper mounting brackets for the front forks. The shorter one is needed for the CB750F bikes and it is the same as used on the GL650 (both naked and Interstate models GL650 and GL650I as both GL650s used dual front calipers) models for '83...GL650 was a one year bike...its lack of popularity (the Silverwing's and the dressed midweight touring bike and dressed bike like it had waned with much of the US buying public.)
The '82-83 GL500I had twin piston dual front calipers and rotors, the GL500 only had the left dual piston caliper.  I can measure the GL500's Caliper bracket mounting spacing to see if it is also compatible...it could have been the spacing was not standardized before the GL650 and GL650I had came out.
The HH pads are worth the upgrade in better braking performance and feel with these dual piston calipers. Naturally best used with a good set of stainless steel braided brake lines so your brakes are firm and not squishy.
« Last Edit: February 21, 2017, 10:41:14 PM by RAF122S »
Offline madScientist
« Reply #48 on: July 23, 2013, 12:52:47 PM »
Attached is a list of bikes that the brake parts can be sourced from.
I ran the part numbers and cross referenced all the bikes. Personally I'm using brackets and calipers from a 85 VT1100C.
The brackets were on less bikes than the calipers.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline jaguar
« Reply #49 on: July 23, 2013, 06:57:29 PM »
No you can't put the twin piston caliper on the single piston brake arm
