Author Topic: CB750 Clutch lock nut size? Need to buy spanner tool (size?)  (Read 9885 times)
Offline VTCBike750
Does anyone know the size of the spanner tool that I need to buy to remove the clutch lock nut.  Ive used a hammer and screw driver before, but figure Id just buy the tool. 20 mm, 22 mm, or 24 mm?
Id go look at the nut, but don't want to take things apart until I'm ready to work on everything.
Thanks guys
There's a cheap on on ebay:
http://cgi.ebay.com/ebaymotors/Clutch-plate-tool-Hub-Spanner-Nut-socket-90cc-110cc-ATV-_W0QQcmdZViewItemQQhashZitem3f0a8d6196QQitemZ270759977366QQptZMotorcyclesQ5fPartsQ5fAccessories
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline Spanner 1
Re: CB750 Clutch lock nut size? Need to buy spanner tool (size?)
« Reply #1 on: June 25, 2011, 02:42:20 PM »
What, someone call me ?
Offline Spanner 1
« Reply #2 on: June 25, 2011, 02:47:41 PM »
The Homda part # for the 750 clutch tool is;07086-30001, but I don't know what mm. Anyone else ?
Offline JohnG
  • 1976 CB750F - original owner
« Reply #3 on: June 25, 2011, 02:59:41 PM »
you can get a 3/8" drive tool made for the job (Honda clutch nuts)  and then get to use an air impact wrench for removing it (and installing).  This is far superior, IMO, to either hammer/screwdriver  or T-handle version, both of which I have done previously.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
« Reply #4 on: June 25, 2011, 04:02:19 PM »
The clutch hub "Nut" is a special nut and it's round, not hex, so you can't just use a normal socket to remove it. Buy the tool, and do it properly. Cheers, Terry.  ;D
Offline JohnG
« Reply #5 on: June 25, 2011, 04:13:30 PM »
while you're buying stuff,  get a fresh nut  and a couple of the sheet metal tabs that go behind it  (although some schools of thought don't use them at all).
After thinking about it, I did work on a bike about a year ago where the nut was on so tight nothing but an air gun would get it off.  Hammer/screwdriver or T handle would not do it, no matter what.  Air wrench makes the job trivial.
1971 CB450
1979 CB750F
1982 CB900F
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #6 on: June 25, 2011, 04:27:07 PM »
Just use some round bar/wire like coathanger stuff. Put it in the grooves on the round nut, then put a socket over it. I have done this many times and it worked every time. Made a tool eventually useing an old plug socket tube.
Offline VTCBike750
« Reply #7 on: June 25, 2011, 05:15:25 PM »
Yes yes. Ive gotten if off before with a screw driver and hammer. This time I wanna buy the right tool, but dont know what size?
Sheet metal tabs? The one washer that locks into the nut?
Anyone know how much to tighten it down too?
-Adam
« Reply #8 on: June 25, 2011, 05:54:42 PM »
That particular tool on EBay uses a 1/2" drive socket wrench mate. According to the factory workshop manual, the torque measurement for re-tightening it is 32.5 - 36.2 foot pounds. Cheers, Terry. ;D
76 k
« Reply #9 on: June 25, 2011, 06:10:17 PM »
yeah, if i remember correctly, its only about 11 bucks and well worth it.
Offline VTCBike750
« Reply #10 on: June 26, 2011, 08:33:52 PM »
[/quote]
[/quote]
Does that seem like a lot?
Kind of like how the factory wants you to torque down the oil drain bolt to 25 lbs-ft in the shop manual.
-Adam
« Reply #11 on: June 27, 2011, 02:10:35 AM »
Yeah, well the book was written by the same guys who built your bike mate, so what are you gonna do? To be honest though I've never torqued a clutch nut in my life, I just tighten it up until I can't tighten it no more........... ;D
Offline matt376
« Reply #12 on: October 02, 2011, 12:13:24 PM »
VTC....  did you ever come across the proper size for the spanner??  I'm in the same boat.
Offline VTCBike750
« Reply #13 on: October 02, 2011, 04:15:41 PM »
I ended up buying this one on ebay.
Very Happy
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270759977366&viewitem=&sspagename=ADME%3AL%3AOC%3AUS%3A1123
Z1 Enterprises also has one:
http://www.z1enterprises.com/Clutch-Hub-Nut-Socket-2161.aspx
Im pretty sure the 750 Clutch uses the 24 mm size.
« Last Edit: October 02, 2011, 04:20:28 PM by VTCBike750 »
-Adam
