Author Topic: Stuck at side of road bike can't kick over!  (Read 3985 times)
Offline RpBet
Re: Stuck at side of road bike can't kick over!
« Reply #25 on: July 03, 2011, 05:42:15 PM »
Not an good omen. :(
Yeah. Oh well, learning curves!  What's your initial best guess?
78 cb750 Cafe'
Offline Roach
« Reply #26 on: July 03, 2011, 06:04:51 PM »
looks like when the cam chain came off it ground down the sides of the case maybe... :o
1978 CB550K Cafe Racer
Offline RpBet
« Reply #27 on: July 03, 2011, 06:24:36 PM »
Let's hope. I can live with that anything to keep the pistons and valves intact.
78 cb750 Cafe'
« Reply #28 on: July 03, 2011, 10:20:03 PM »
Those pieces are HUGE..!!
 Maybe the cam bolts backed off.
 That amount off debris may have slowed the oil flow to the pump, which would cause pressure to drop..
« Last Edit: July 03, 2011, 10:22:59 PM by 754 »
« Reply #29 on: July 03, 2011, 11:03:17 PM »
How did the aquarium gravel (blue and amber colored bits, and the dotted shell near the center of the pic) get in your oil pan? The aluminum chips look like they came off a drill or end-mill; not like when a cam chain saws into the chain tunnel.
« Reply #30 on: July 04, 2011, 12:02:09 AM »
That amount of Cr*p means a last nut and bolt stripdown, meticulous inspection/cleanout and careful rebuild FORGET any idea of just doing the top you are just throwing money away
« Reply #31 on: July 04, 2011, 12:14:31 AM »
Took my bile out for it's maiden voyage. I may have pooched something. I can't kick her over. She feels stuck. I was running 20 psi at the oil gauge. What should a 78 cb750k have for pressure running and at idle. Help!
your first post wasnt wrong,you certainly did take your bile for a run!
Offline wingman1946
    • BCINKART.com
« Reply #32 on: July 04, 2011, 06:55:19 AM »
Holly Macaroons !!! Wasn't there some noise involved with this happening?
« Last Edit: July 04, 2011, 07:02:18 AM by wingman1946 »
Offline RpBet
« Reply #33 on: July 04, 2011, 07:51:59 AM »
No noise. I came to a stop sign and she bogged down. Never to turn again.
Well, I will be pulling the motor tonight. Thanks again to all, and I will keep you guys posted.
78 cb750 Cafe'
Offline wrenchmuch
« Reply #34 on: July 04, 2011, 05:44:18 PM »
I agree with Roach . I bet that debris came from the cam chain tunnel . I hope its not as bad as it looks .
CB750K1
CB750K4
Offline RpBet
« Reply #35 on: July 06, 2011, 04:02:14 PM »
So far Roach is correct. Looks like the screw holding the cam sprocket started to rub.
78 cb750 Cafe'
Offline RpBet
« Reply #36 on: July 06, 2011, 06:43:39 PM »
More damage to the top end. Looks like when the chain jammed it broke off the "ears" on the cam. Good thing I picked up a parts bike for $250 last year. I think I just made my money back.
[attachment deleted by admin]
78 cb750 Cafe'
Offline Spanner 1
« Reply #37 on: July 06, 2011, 08:57:01 PM »
Wow...... call Mike Rowe of 'Deadliest Catch' he might know whats in your sump.... just kiddin'. Sorry you had such a bad thing happen  :(
