Author Topic: Standard Spark Plug Wrench Won't Fit!  (Read 7156 times)
Offline breezy
    • Artist's Portfolio
« on: July 03, 2011, 09:36:55 AM »
Being a new SOHC4 owner, I was a bit surprised to find that a standard spark plug socket wrench won't fit past the valve cover.  What sort of plug socket works?  Should I try to find the pressed metal sockets wrenches that generally come with the stock tool kit?  Are these available singly?
Offline tory b
Re: Standard Spark Plug Wrench Won't Fit!
« Reply #1 on: July 03, 2011, 09:45:40 AM »
I had the same issue,I just turned down a standard plug socket and added it to my "Special motorcycle tools"drawer.
1975 CB400F
1973 CB500
1982 CB900F
1983 GL1100 W/Vetter sidecar
www.vintagericeburners.com
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: July 03, 2011, 09:48:05 AM »
Yes.  What you need is either a spark plug socket made for motorcycles (still available at your local shop), or a thin-walled deep 18mm socket.
pamcopete
« Reply #3 on: July 03, 2011, 09:50:21 AM »
I use a 18mm "Gear Wrench" socket from Advance Auto, but the other issue is that the NGK spark plugs are 18mm but some other brands, like Autolite, are 11/16".
Offline DJ_AX
« Reply #4 on: July 03, 2011, 09:58:25 AM »
I got a nice thin walled socket with the rubber inside to hold the plug.
And yes... those kits are still available. Just bought one (like a pressed tube + a separate 4" post that you insert in the holes on the other end to turn). I keep that one on the bike.
Edit: What SOHC4 do you have?
« Last Edit: July 03, 2011, 10:00:15 AM by DJ_AX »
Offline BeSeeingYou
« Reply #5 on: July 03, 2011, 10:01:09 AM »
I have an 18mm Craftsman plug socket from Sears and it fits fine.
Offline zackblack
  • Give my creation... Life!
« Reply #6 on: July 03, 2011, 07:38:38 PM »
I have a 18mm from Canadian Tire that works.
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline WarwickE36
« Reply #7 on: July 03, 2011, 08:26:44 PM »
18mm socket with about 1/4 cut off with a cutting wheel..
I use it to break it free then use an old plug wire boot from a town car to turn take it out the rest of the way, I also use the old boot to install them and only use the 18mm to torque it down.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Logan80
« Reply #8 on: July 04, 2011, 05:14:36 AM »
This is a very good idea. Can help avoid damage to the head or plugs.
« Reply #9 on: July 04, 2011, 09:58:18 AM »
The wrench that came with the original toolkit is the best tool. You can still buy them.
Offline octagon
« Reply #10 on: July 04, 2011, 10:20:47 AM »
this is already on the forum somewhere, but a piece of rubber tubing with an id a little less than the od of the plug ceramic works very well to thread a plug on and off.
Offline DJ_AX
« Reply #11 on: July 04, 2011, 04:18:21 PM »
like ... and extra chunk of left over fuel line.
Offline Bahumut
  • Ugh, wait what?
    • anotherdamndj.com
« Reply #12 on: July 04, 2011, 04:23:28 PM »
I bought the same one this morning.  Works fine.  About $3
'77 CB550K - current teacher of patience and things mechanical
'08 KTM 690 Duke - teacher of backin' it in on public streets and collector of traffic tickets
