Author Topic: Stripping paint  (Read 2780 times)
Offline mark52
  • 1975 cb750 k5
Stripping paint
« on: July 06, 2011, 07:36:23 PM »
Hey all, I need the help from some of you that are expert painter. I am at the point in my project where I need to strip paint off my gas tank and side covers. The paint on the tank is original and the side covers have been rattle can to death. Any tips you would like to share concerning process or products would be much appreciated. I really know nothing about the best way to prepare the surfaces for paint. Oh, the bike is a 75 750k, and the paint color is planet blue.  Thanks
Mark
Re: Stripping paint
« Reply #1 on: July 06, 2011, 07:46:36 PM »
I am in process of stripping the tank on my K7. I'm using Kleen Strip, just brush it on, wait 20 min and scrape it off. I've done one pass and approx 50% of the two coats have come off.
There may be a better product, but this one is cheap and easy.
Re: Stripping paint
« Reply #2 on: July 06, 2011, 07:51:18 PM »
One bodyshop trick is to put plastic wrap over the stripper and let it sit. It stops evaporation and the stripper works more completely.
Offline mark52
  • 1975 cb750 k5
Re: Stripping paint
« Reply #3 on: July 07, 2011, 03:10:12 AM »
Thanks, any other tips or hints. Will that stripper also work on the side covers? Given all the great paint jobs I've seen on here I thought more ideas or opinions would be offered. Is this something best left to "professionals"? While I will have someone who hopefully knows what they are doing actually paint these pieces, what should I do to the surfaces after I get the paint off?
Mark
Offline greenjeans
  • 1972 CB750K2
Re: Stripping paint
« Reply #4 on: July 07, 2011, 05:18:28 AM »
Aircraft stripper on the tank.  Then you can take some sand paper to it to give it some tooth for the primer to stick to.  If the side covers have been spray-bombed, you might try the reducer that you will be using for the paint.   You just need to get rid of the spray-bomb paint.    You might just have to hand sand the side covers until you get down to the original paint.  It does not all have to come off - better if most of it stays there.  It's been there for 35 years or so.    I've yet to see the factory paint flake, peel or come off the sidecovers - makes a good base.
* You might consider new sidecovers from forum member Frankenstuff - http://forums.sohc4.net/index.php?topic=74022.0
good qualily - fair price.    You'd make up the price on labor if you are using a body shop.
Offline Psychonaut
Re: Stripping paint
« Reply #5 on: July 07, 2011, 05:28:40 AM »
I like the stripper in the spray can with the 747 on it, Mar Hyde Tal Strip. I've used Jasco brush on too. You will need to rinse with water with any stripper. This is what I don't like, it is now two steps before paint and a risk of the metal oxidizing.
I would only strip the tank if it had been repainted. If you take it to bare metal it will need to be atleast primed, preferably sealed. Painting over paint is completely acceptable if it is sanded.
Offline Lostboy Steve
Re: Stripping paint
« Reply #6 on: July 07, 2011, 06:02:29 AM »
Find a guy who powdercoats to blast the tank. Shouldn't cost much, he may even do it for free. The side panels gotta get sanded.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Re: Stripping paint
« Reply #7 on: July 07, 2011, 06:05:54 AM »
I have new side covers that don't need stripping but be cautious using the stripper on plastic, it could cause damage.
Offline MoMo
  • Ride like you're invisible
Re: Stripping paint
« Reply #8 on: July 07, 2011, 06:32:17 AM »
+1 Do not use stripper on fiberglass/plastic unless it says it is safe for that base...Larry
Re: Stripping paint
« Reply #9 on: July 07, 2011, 08:10:36 AM »
Yeah i learned that the hard way once....
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Unded
Re: Stripping paint
« Reply #10 on: July 07, 2011, 08:24:20 AM »
I bought a soda blaster from harbor freight, works pretty damn good on everything I have used it on thus far. If you are gonna be polishing a bunch of various parts it's a good buy at $150, if it's just gonna be the tank take it to a powder coating shop, it's well worth the money to have it done and it shouldn't cost much.
Offline mark52
  • 1975 cb750 k5
Re: Stripping paint
« Reply #11 on: July 07, 2011, 05:25:54 PM »
Thanks all good advice. The OEM paint on the tank is not to bad, a few rust spots, no dents, but sun faded and gas stained. Do I not have to at least strip the clear coat to get the decals off? Also  what grade of sandpaper should I start with on the side covers? I assume I will need to get all of the paint off the side covers since its rattle can and not OEM.
Mark
Offline MoMo
Re: Stripping paint
« Reply #12 on: July 07, 2011, 05:32:07 PM »
Mark,  there is such a thing as fiberglass stripper. Google it, might save you some elbow grease ;). I am not a paint guy by any stretch but I would start with 220 wet/dry if I were doing it...Larry
Re: Stripping paint
« Reply #13 on: July 07, 2011, 06:42:58 PM »
I would take the tank down to bare metal. Just sayin'...
Offline nitroeagle
Re: Stripping paint
« Reply #14 on: July 07, 2011, 07:08:28 PM »
Oven cleaner works well for stripping paint. Spray on & let it soak. Definatly sand the covers. Most important, wipe all down with wax & grease remover using a lint free clotch. Oils from your skin will mess up the paint.
Offline Kong
Re: Stripping paint
« Reply #15 on: July 08, 2011, 05:40:16 AM »
I don't know if you understand just how poor a quality nearly all rattle-can paints are but almost any of it will wipe right off with a rag soaked in Acetone.  Of course that will only take you down to the original paint, and there you are going to have to sand.
As for the tank, you have two choices and if you had posted some good photographs of your parts I could probably save you to the trouble of having to make the decision yourself as to which way to go.  But you didn't post photos.  So, here are your choices, you either have to take it to bare metal, or you can leave the original finish on there if it is sound and just prep it for the next paint.  So that's the key, is your original paint sound?  I don't mean has it faded and I don't mean does it have a scratch or two in it somewhere - but no dents.  What I mean is if the paint is unbroken and adhering completely everywhere with no rust at all.  If that is the case all you have to do is sand it with 400p paper and then seal it and you'll be ready to paint.  The same thing is true of the side covers.  If you wipe all that rattle-can crap off of it with Acetone and find that there is stock paint under it that is in good shape, then just wet sand it with 400p paper and move on.  However with the side covers once you get the trash-paint off of it it really doesn't matter what you find below it because you're still going to have to sand them flat and smooth before you seal them.
Back to the tank.  If you brought the tank to me I would have it down to bare metal in less than 20 minutes.  Put an 80 grit wheel on an angle grinder and you can do it too.
In any event, once you have your old paint off the parts you need to protect them.  You do this by sealing them.  For a sealer you use a special type of paint that is hard, somewhat flexible, and impervious to other chemicals (except Acetone) and paints but still able to provide an outstanding bond to both the surface under it and the things that will be applied to it.  There is only one good product for this - epoxy primer.  Go to your local automotive paint supplier and ask for a quart of the PPG Omni line of Epoxy (and catalyst).  Depending on what color of it you want (get gray or white) the number will vary but tell them you want MP-170; the gray is designated MP-171 and the white is called MP-172.  You can thin this stuff slightly with 10% acetone when you use it for a final sealer coat, but for your first seal to protect the metal just go ahead and shoot it unthinned.  After that do your preparation in the normal way.  I'll outline it for you:
First you to to a sound base or bare metal.
Next you seal the bare metal to protect it from rust, this is done with epoxy primer.
Next you apply any body filler you might need and sand it to shape.
Next you reseal to protect any metal that was exposed during sanding.
Next you spray multiple coats of high build (2K) primer
Next you block sand the parts to perfection
Next you seal the surfaces prior to painting, here with thined epoxy (10% Acetone) - this primer will NOT be sanded
Next you shoot your base-coat color(s)
Next you shoot your clear coat
Finally you cut and buff the parts
Before you shoot any of the paint products go to the manufacturer's web site and find the Tech Sheets for the product you are using and read it, then follow it.  The tech sheet will tell you what you need to know to apply the paint properly.  One of the things the sheets will tell you is the size gun cap you need to use.  Most of them will give you a wide range but if your gun falls outside of it by a little bit don't worry about it.  As an example the Tech Sheet for that MP-170 tells you to use a gun between 1.3mm and 1.6mm, but I've shot it with a touch up gun with a 1.2mm cap for years with no problem.
So by now you're probably thinking one of two things.  The first, and most common response, might be "Dear sweet jesus, what have I got myself into here?  Maybe I should just pay someone to do this".  That might be the smartest thing to do.  But then you might have had the other response.  That's the one that goes like this, "Hey, I can do this!  I've been wanting to try my hand at painting and was just looking for some sort of instructions; this looks easy enough."
You have to make the choice, but let me tell you this to help you along.  Anybody can paint.  Don't let anyone convince you that its some sort of dark art only learned after years of practice with gawd-awful expensive equipment - it just ain't true.  All you have to do is follow the instructions, pay attention to what you're doing, and loosen up - let it flow.  Anybody can paint.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
