Author Topic: whining sound cb400  (Read 4854 times)
Offline kajtek
whining sound cb400
« on: July 08, 2011, 08:21:43 AM »
ever since ive owned it my bikes has made quite an unpleasent whining sound.
its barely there when i start it and gets worse as the engine warms up.
to describe it... it kindof reminds me of a car in reverse..
doesnt happen in neutral, only with gears enganged, and doesnt have to be moving so hold the brake and pull the clutch out a bit and you get the noise.
any ideas? or is this a trait of the bike? seems to me from moving my head around that its coming from the stator side of the crank..
thanks
ashley
1978 honda cb400f supersport
Offline -CB-Jamie-
Re: whining sound cb400
« Reply #1 on: July 08, 2011, 08:38:50 AM »
Have you tensioned your drive chain too much? that can cause a whining noise.
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline smashedmelon
« Reply #2 on: July 08, 2011, 10:57:24 AM »
this is a shot in the dark, but I had a whining noise issue that ended up being my tach cable needing some lube.
CB750K5, CB750 K3 parts bike, CB750K3 baby-cakes
Offline kajtek
« Reply #3 on: July 08, 2011, 11:23:03 AM »
Drive chain correctly tensioned and no tach cable... Basically it only makes the noise under load, any other suggestions?
Thanks
Ashley
« Reply #4 on: July 08, 2011, 11:27:57 AM »
The whine on my bike turned out to be my ex-wife. It has been gone a long time, now.  ;D
« Reply #5 on: July 08, 2011, 01:53:20 PM »
...just got done working on a buddie's cb400, made the same noise on test rides, I don't know what it is but I found it mildly pleasing :)
Offline Kevin400F
« Reply #6 on: July 08, 2011, 02:40:21 PM »
Just a guess....bad bearing on the primary shaft.
Kevin
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #7 on: July 08, 2011, 02:50:45 PM »
"The whine on my bike turned out to be my ex-wife. It has been gone a long time, now. "
Bikes parked out front mean good chicken-fried steak inside.
Offline kajtek
« Reply #8 on: July 08, 2011, 03:34:54 PM »
Kevin
That's kinda what I was thinking but hoping not!!!
Offline camelman
  • Man... Myth... Legend
« Reply #9 on: July 08, 2011, 03:40:22 PM »
You might be able to locate the whine with the old screwdriver trick. Stick a screwdriver handle to you ear and the other end to various parts of the engine, and you'll hear local noises.
Canelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline sopo400f
« Reply #10 on: July 08, 2011, 05:37:12 PM »
The screwdriver trick might work if he has a side car:P
I have the exact same issue, only whines underload.
1975 cb400f blue
Offline dadeo
« Reply #11 on: June 29, 2012, 07:12:38 AM »
Hi, im just wondering if you ever figured out this problem? Im having similar trouble.
Offline camelman
« Reply #12 on: June 29, 2012, 02:18:00 PM »
I've noticed this on the few 400Fs I've had. I just thought it was normal. The exhaust on the 400 is pretty quiet, so you might hear more engine noise than on other SOHC4s.
