Author Topic: 350f carb rack  (Read 754 times)
Offline nk140
350f carb rack
« on: July 13, 2011, 08:46:04 PM »
I am reassembling my 350f carb rack and can't figure out where the spring is suppose to attach between the 2-3 carbs.  Is there suppose to be a post/bar between the carbs?  If so I think I lost mine is the past week or two in the garage somewhere.  Any help is much appreciated.  Thanks
Offline RickB
    • Pop Magazine
Re: 350f carb rack
« Reply #1 on: July 14, 2011, 03:53:51 PM »
NK,
Yes there is a little metal pellet with a grove through it that the spring connects to. It slots into a hole behind the T shaped fuel junction. You can see the shape of the part on this CMSNL diagram. It's right below the spring that is labelled 100.
I doubt you can buy the part anyway as it doesn't have a part number. However someone with a bunch of carbs parted out may have it. Alternatively you can just use a small piece of metal rod cut to fit.
Rick.
« Last Edit: July 14, 2011, 10:09:42 PM by RickB »
Offline nk140
Re: 350f carb rack
« Reply #2 on: July 14, 2011, 06:59:48 PM »
NK,
Yes there is a little metal pellet with a grove through it that the spring connects to. It slots into a hole behind the T shaped fuel junction. You can see the shape of the part http://images.cmsnl.com/img/partslists/engine-group-1j-1k-2j-2k-cb400f-australia_bigma000080e01-4_c702.gif]on this CMSNL diagram[/url]. It's right below the spring that is labelled 100.
Rick.
Thanks for the info.  I couldn't find the piece that you speak of.  I did use a small piece of metal in its place.
