SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
braking capacity reduced due to "polished" bits?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: braking capacity reduced due to "polished" bits? (Read 609 times)
jvandyke
Enthusiast
on:
July 15, 2011, 12:24:14 PM »
While at a gathering of vintage Japanese bikes last night, I mentioned I was not happy with braking capacity. I went through everything this spring as I had a draggy front caliper for a while last year, one guy mentioned that the draggy caliper could have polished the disk and pads to the point they slide too easily. Does this sound feasible? The disk feels like glass it is so smooth. Pads looked fine and had plenty of meat so I did not swap 'em out. Should I try to get the disk turned and get new pads or what?
Logged
1972 CB500, 7500 miles, in family since '73
Really?
I've come to the conclusion that I AM a
Really Old Timer ...
Re: braking capacity reduced due to "polished" bits?
Reply #1 on:
July 15, 2011, 12:49:37 PM »
He might of meant that it has a glaze on it. You can wet sand the disc if you want, cheaper than having them turned. I used 320 wet. Some use a little coarser.
But don't get in your head that it will be night and day when you do this. I don't know what you are comparing the braking ablity to but these are not dime stoppers. If you are referring to how it was when new, it may be more than just a glaze on the disc (i.e. brake line swell due to age).
Logged
I don't have a motorcycle, sold it ('85 Yamaha Venture Royale). Haven't had a CB750 for over 40 years.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
flybox1
My wife thinks I'm a
Reply #2 on:
July 15, 2011, 12:53:31 PM »
deglazing with fine emory cloth will matte the disc a little.
refurbish your master cyl, put on some braided, bleed it, and know the brakes on these bikes are, as TipperT stated, "these are not dime stoppers"
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
jvandyke
Enthusiast
Reply #3 on:
July 15, 2011, 01:07:06 PM »
Thanks guys, I'll scuff things up a bit and consider a SS line. I know I won't be doing stoppies and they were never famous for braking capability but I think it should be a little better than what it is.
Logged
DJ_AX
Expert
Reply #4 on:
July 15, 2011, 01:16:53 PM »
SS lines make a huge difference!
Worth every penny of there's ever a chance you may need to stop quickly. And there's a good chance of that no matter how or where you ride.
Before the SS lines there was a couple of times where I had to use my escape plan B (off road or splitting lanes) thanks to freeway brake slammers and no thanks to weak brakes.
After the SS lines there's already been a few equally quick stops where I didn't need to use the escape route!
rush hour
There's an SOHC member here that sells them. Look at the "Bikes / Parts for sale" section of the forum.
... highly recommended.
Logged
~ Vincent . . . '75 CB750 K5 . . . '97 BMW r1100rt . . . had; '75 CB550 K1 (sold) . . . '73 CB350G (gifted) HELL YEAH!
Disclaimer: I could be wrong.
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
