Author Topic: Final hurdle to a full carb rebuild  (Read 2992 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Final hurdle to a full carb rebuild
« Reply #25 on: July 21, 2011, 11:40:51 AM »
if you think the pilot jets are small tolerances wait till you start messing with the needles. I little bit of crud naked to the eye can make your bike run too rich. Moving the needles two tiny notches can make your bike go from too rich to too lean. Just like that. Then after all that you need to vac sync all over again.
I wouldn't worry about how far the slides go down just adjust them with a 1/8" drill bit on the engine side of the carb. If everything else is clean: all jets and valves and air passages and needle surfaces, floats are adjusted (just as the float tab hits the plunger with no pressure) and work properly, put the carbs back on the bike. Double check the floats with the clear tube tool. EVen without the airbox attached it should still start and run good enough to give it a vac sync and you should be riding it soon enough. I usually don't put my ancillary stuff back on, like hoses and intake plenum rubbers, until I know I'm done with the carbs.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #26 on: July 21, 2011, 11:53:30 AM »
I got them back on, and they seem to be running on all 4 cylinders.  Good call on the pilot jet clog. Thanks!
It's still hanging, and I'm not sure why.  If this is pod related (cheap emgo pods) then I will just wait for the boots to arrive.  I have checked for air leaks, but intakes seem ok.
Thanks for all your help.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
« Reply #27 on: July 21, 2011, 12:59:03 PM »
But a couple satisfying blows with a mallet did the trick :)
my Pappy always said to have a BFH nearby...
