Author Topic: Will this headlight setup work, and what do you think  (Read 1628 times)
Offline Gibblet
« on: August 13, 2011, 11:39:31 AM »
I was going to buy these ears:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380361657707&viewitem=&sspagename=STRK%3AMEWAX%3AIT#ht_4173wt_902
And bolt these turn signals right into the headlight bucket, they are 10mm.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p5197.c0.m619&item=200639439468&viewitem=&category=35575#ht_6011wt_772
will that work, and will it screw up the ground since the nuts on the inside have grounds.  if those blinkers wont work any suggestions?  thanks.
1978 CB750f
1980 CM400t
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: Will this headlight setup work, and what do you think
« Reply #1 on: August 13, 2011, 12:51:52 PM »
Those turn signals should work. You can find these shaped turn signals from dime city. Not sure if they have chrome, mine are "billet" ones. I know for a fact they work. they are cheaper too. Make sure you get the 3 wire/dual filament type for the front running lights.
I have them on stock ears, so you may need ears with holes in them for options when you swap.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Gibblet
« Reply #2 on: August 13, 2011, 10:24:06 PM »
i was planning on bolting them straight into the headlight through the aftermarket ears.
1978 CB750f
1980 CM400t
Offline m in sc
« Reply #3 on: August 14, 2011, 05:28:45 AM »
it will work. that bolt will thread into the stock cb grounding bolt in the bucket, same thread pitch/size.
Offline johnrdupree
« Reply #4 on: August 14, 2011, 06:49:44 AM »
I have a similar setup on my 550 and it worked first time out.  The only potential problem I see is if you have to use the rubber spacer shown in the auction pic, it may screw up your ground.  Make sure the ones you're looking to buy are 35mm, or find some 35mm ones.  A quick search shows Mikes XS has them: http://www.mikesxs.net/products-77.html#product-09-0016
It makes for a nice, clean setup:
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline mrrch
« Reply #5 on: August 14, 2011, 07:06:35 AM »
You copying me?
Just kidding, they work and fit great.
my build
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: August 14, 2011, 07:21:39 AM »
Those ones in mrrch's pic are the same ones I have. $16 at dime city, but again, make sure you get the dual filament for front, single for the back, if you are going for matching 4.
~Sophocles
Offline Gibblet
« Reply #7 on: August 14, 2011, 08:13:31 AM »
Mrrch, yup.  Thats exactly what im going for, updated but not weird new LEDs.  I just bought it all from dime city, along with a few other updates.  Ill post up a pic when done,  thanks for reminding me about the front dual filiments, i almost botched that.
1978 CB750f
1980 CM400t
Offline Gibblet
« Reply #8 on: August 15, 2011, 06:49:19 PM »
ordered bracket from XS and lights from dime.  Hopfully have it done by the weekend.  Ill post up pics.  You think its easier to take the stock ears off from the top or bottom?  probably the top right?
1978 CB750f
1980 CM400t
