Author Topic: Play in the front sprocket?  (Read 1072 times)
Offline Rgconner
« on: August 23, 2011, 10:36:44 PM »
Should the front sprocket and retaining clip have play in it? Seems like there should be a spacer there behind it and the bearing to keep it from wobbling.
or am I in for a new sprocket?
1975 CB550K aka "Grease Monkey"
Re: Play in the front sprocket?
« Reply #1 on: August 23, 2011, 10:38:48 PM »
It needs that play. This allows for some misalignment in the swingarm and frame during hard acceleration.
Offline Rgconner
« Reply #2 on: August 23, 2011, 11:05:41 PM »
Righto.
I guess that makes sense.
Btw, got those brass bushings in... what a ^&#@$^@! You are way under priced at $200!
Offline Toxic
« Reply #3 on: August 24, 2011, 04:01:48 AM »
I thought the same thing when I was putting mine together but like you I was reassured it is normal.
bollingball
« Reply #4 on: August 24, 2011, 06:00:02 AM »
The first time I took mine off I saw that play so I shimmed it tight. Did not take long before I noticed shinny parts on the side of my sprockets big mistake, Good thing was the chain was shot. Now I have three new parts and NO shim.
« Reply #5 on: August 24, 2011, 06:47:39 PM »
Righto.
How did the swingarm clearance come out with those bushings? (I.e., can the back axle move side-to-side at all, now that it is all back together?)
Offline Rgconner
« Reply #6 on: August 24, 2011, 11:16:09 PM »
No play at all, swing arm slowly decends by itself.
Rather impressed with myself, actually.
