Author Topic: Halogen vs led headlight  (Read 23184 times)
Offline KurtK
« on: September 21, 2011, 04:16:59 PM »
My 500k2 has just been converted to a 35/35W halogen headlight.
It works fine.  I was wondering if anyone has any experience with a H4 led headlight bulb that may or should but out more light on 5 watts?
Offline 65Ch3v3LL3
Re: Halogen vs led headlight
« Reply #1 on: September 22, 2011, 02:42:32 AM »
I run the Truck-Lite 7" LED light on my Harley. Way more light output that the stock lighting and a much better quality light. Added benefit is the current draw is extremely low. There is a YouTube demonstration of it where they fully power the light on 8 AA batteries. I think the only negative would simply be the looks on the vintage bikes. It really doesn't go with the styling but the low current draw would certainly help the older weak charging systems.
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #2 on: September 22, 2011, 05:43:46 AM »
The Truck-Lite 7" LED light has the following ratings:
2.5 amperes on low beam (32 watts) - ONLY 3 watts less (than the 35 watts quoted in the initial post).
4.5 amperes on high beam (57.6 watts) - 22.6 watts MORE (than the 35 watts quoted in the initial post)!
Not the huge "power saving" headlight that you may think, and in fact is worse (on high beam) . . . just a heads up.
My source of info:  http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=64057&langId=-1
« Last Edit: September 22, 2011, 06:49:13 AM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline KurtK
« Reply #3 on: September 22, 2011, 06:20:42 AM »
I appreciate the info.
This reminds me of the movie Apollo 13 where the substitute astronaut was in the simulator running tests to try to save a few watts to get the men back to earth.
Offline 65Ch3v3LL3
« Reply #4 on: September 22, 2011, 06:38:08 AM »
4.5 amperes on high beam (57.6 watts).
Not the huge "power saving" headlight that you may think . . . just a heads up.
It is a considerable amperage savings when the average halogen bulb consumes 5 amps on low beam and up to 10 on high depending on the wattage of bulb.  The LED light runs about 50% of the current required for a Halogen.
1979 CB650
1922 Ford T-Model
« Reply #5 on: September 22, 2011, 06:48:10 AM »
My comment was targeted to those that are looking to save power (over stock).
I agree that the LED bulb may be a good alternative for those that are considering higher powered halogens, but to say, or imply, either intentionally, or not, that the LED bulb consumes less power than stock is not always correct.
Just adding some numbers to the discussion, so people can make the best decision for them.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: September 22, 2011, 08:20:24 AM »
If you want more light then get a 9004 55/60W H4 bulb for about $8. The stock bulb drew 40/55 or somewhere in that neighborhood so it's not much more of a drain as long as your charging system is in good shape and almost twice the light output. I run a 35/35W in the city but it's mostly for being seen and not lighting up the street. I have an extra 55/60W bulb if I ever need it for dark country road riding.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Patrick
« Reply #7 on: September 22, 2011, 08:52:25 AM »
Geez, that's more than I paid for any of my bikes.....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #8 on: September 22, 2011, 11:23:57 AM »
How expensive are these LED headlights?
Offline Pinhead
  • 1979 CB652-ST
« Reply #9 on: September 22, 2011, 11:29:01 AM »
Wow, I've been hoping LED tech would overtake incandescents for headlights, but $250 is a bit steep for a light!
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline vames
« Reply #10 on: September 22, 2011, 11:36:47 AM »
They don't seem to be too expensive -- less than $10 for a H4 LED bulb -- as long as you already have a H4 reflector.
Has anybody used something like this? They don't really give the "wattage equivalent" light output (ie. 55w/65w) for a regular halogen bulb nor any comparison for power consumption. But it does look interesting.
Please report back.
http://cgi.ebay.com/ebaymotors/Car-H4-3528-102-SMD-LED-White-Headlight-Bulb-Head-Light-/130561376253?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e66107ffd
Offline Patrick
« Reply #11 on: September 22, 2011, 11:47:41 AM »
For $5.09 plus free shipping I'm thinking that bulb is worth a look. I ordered one. I will let you know how bright it is compared to a sealed beam 55/65 and an H4 with reflector.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline vames
« Reply #12 on: September 22, 2011, 11:52:52 AM »
Probably will take a week or two to come in from Hong Kong, but you're right -- it's too cheap to not try. Let us know!!!!
Offline KurtK
« Reply #13 on: September 22, 2011, 11:59:55 AM »
I ordered one as well will let you know.
Offline vames
« Reply #14 on: September 22, 2011, 12:06:05 PM »
On second look, do these things have high/low? It has three prongs on the hookup, but they don't say anything about high/low. Very interested to hear back.
Offline KurtK
« Reply #15 on: September 22, 2011, 12:17:43 PM »
I thought of that..I bet no high /low, but I don't care if it lights up the road well at low power draw.
Offline Patrick
« Reply #16 on: September 22, 2011, 12:22:14 PM »
Without H/L, it is not an H4. Without H/L, what is that third prong for?
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline KurtK
« Reply #17 on: September 22, 2011, 12:25:55 PM »
Don't know but I'm going to play with it when I get it.
Offline xsmooth69x
« Reply #18 on: September 22, 2011, 02:05:09 PM »
you own a truck light 7'  :o
i want one of those so so so so so so so bad but i cant drop $250+ for one......
that thing must look awsome!!! do you have any night shots of it with the high beam and low beam  :)
why dont you go with HID? 35w bright as F
http://www.v-leds.com/Exterior-HID-Headlights/H4-9003-HB2/H4-HighLow-BiXenon/V-HIDS-35W-SLIM-BALLAST-p4961322-1-2.html
at your house for $55-60 shipped they have like 3000k, 5000k, 6000k blue purple or white
« Last Edit: September 22, 2011, 02:08:55 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
« Reply #19 on: September 22, 2011, 02:10:59 PM »
I found this earlier today, but failed to share it - my bad.  It is a review - including at night pictures, comparing various bulbs.
http://theroadhawgs.com/uploads/Review_LED_Headlights__1_.pdf
Offline xsmooth69x
« Reply #20 on: September 22, 2011, 02:54:17 PM »
those JW speakers lights are nice and bright to bad they dont look cool....
trucklite is still my vote! sick btw awesome info!
Offline KurtK
« Reply #21 on: October 06, 2011, 11:15:13 AM »
Well the experiment was not successful .  I ordered the LED from Ebay though China.  It arrived in two weeks.  Last night after work I put it in my 500K-2.  It only works on low beam no high beam.  Looking at the voltmeter the 35/35w halogen took the battery down to 11 volts without the motor running the LED took it to 11 1/2 volts.  The light looked fine last night, nice and white and it seemed to be very broad and fill in a lot of dark spots up ahead.  Today however in the light of day when you turn on the light it just does not seem very bright.  I put the 35/35w back in the headlight and it seems brighter in the daytime...where I do all or most of my riding.
Offline phil71
« Reply #22 on: October 06, 2011, 11:50:29 AM »
So halogens are better for daytime riding? I couldn't be more confused right now.
Offline KurtK
« Reply #23 on: October 06, 2011, 11:54:34 AM »
Don't know Phil...it just seems that the halogen showed up better during the day.  The LED needs to be bigger use to show up better, but I can't find one on ebay.
Offline phil71
« Reply #24 on: October 06, 2011, 11:56:33 AM »
But the LED is brighter at night?
