Author Topic: GL1000 forks on a k3 through k6?  (Read 855 times)
Offline emitch
« on: September 29, 2011, 09:46:26 PM »
Will a gl1000 front end fit on cb750 k3 through k6 frame? If so, what years of gl1000 are compatible?
Theres another thread going on right now about gl1000 forks, but I didn't want to hijack that thread with my question. Thanks in advance for anyone who can shed some light on this for me.
KingCustomCycles.com
Re: GL1000 forks on a k3 through k6?
« Reply #1 on: September 30, 2011, 07:21:20 AM »
Yes, all the SOHC frames use the same neck dimensions 69-78 as far as I know.  I have never had a problem switching years around.  The GL1000 frontends to use are the early ones with the loose balls inside.  If it has tapered bearings, it has been modified, or is a later year.  I think 75-77 are the years for the GL1000.
« Last Edit: September 30, 2011, 07:22:55 AM by KingCustomCycles.com »
