Author Topic: looking for help on exact year and make.vin# cb750e-3100272.had varied answers.  (Read 2171 times)
Offline mr.brandon
went to honda on line and got a varied answer.possible transitional year, but need to know for certain what year and model vin # cb750e-3100272 comes from. i am thinking the e is a super sport tag, but clues lead me to believe that it may not be. thank you for your help. mr.brandon
Offline CycleRanger
  • No comment about being an
Here's serial numbers by years: http://www.sohc4.net/?p=111
Is that number from the engine or the frame?
Offline lucky
That list and link posted will not work. It is incomplete.
That number is the engine number.  " E" is for engine.
It is a 1978 engine.
Starting CB750E-3000001 =1978.
  CB750 K,  if it is an automatic would be CB750A
CB750F also.  Need to see photo.
The frame number is on the steering head of the motorcycle.
It is stamped into the left side and there is a glued and riveted foil tag on the right side of the steering neck. All motorcycles are like that.
Too bad you did not help us and show us a photo of the motorcycle.
The gas tank must have that hidden gas cap under a lift up lid. Right?
« Last Edit: October 14, 2011, 02:17:05 PM by lucky »
Offline CycleRanger
You mean the link doesn't work or the list itself is bad??
The link works fine, I can't vouch for the accuracy or completeness of the list.
It does have F engine serial numbers that start at 3100001.
I vote for 1978 CB750F3 engine. What number do you find on the top head fin intake side next to #3? (of course heads can be swapped around). Is it black? (any engine can be painted)
Offline lucky
The list is incomplete.
Mr. Brandon, Can you just please post a photo. Thanks.
