Author Topic: Installation battery status monitor  (Read 976 times)
Offline dakota
« on: October 18, 2011, 01:30:51 PM »
Hi,
I have bought a BSM (battery status monitor) from http://www.aoservices.co.uk/data/bsm.htm
The BSM is a limited range LED voltmeter, designed to monitor the voltage across a 6V or 12V lead-acid battery.
The BSM will change colour dependent on its input voltage; the colour will indicate the operational state of the battery.
Connection: join the positive (RED) and negative (BLACK) wires to the ignition circuit and earth.
So, where is the best place to cut the wires and connect the BSM?
thx,
gp
Offline Bob3050
Re: Installation battery status monitor
« Reply #1 on: October 18, 2011, 03:13:19 PM »
Dakota:
        I would think in the headlight case would be an easy hook-up. The way I understand it you connect the red to a lead that gets hot when the ignition is on and connect the black to ground. You could connect it using jumper leads just to test it.
  Bob
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: October 18, 2011, 09:16:47 PM »
I installed a Battery Bug (similar gauge) I connected each wire to the opposite ends of my battery cables. Red to the solenoid, black to the frame. It doesn't draw enough juice to drain the battery at all.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
