Author Topic: where to get 530 sprockets for 750f ?  (Read 2179 times)
Offline Serge
  • cb750f 1978
« on: May 15, 2006, 09:57:39 PM »
Hello, what is the best place to buy 530 or 520 sprockets and chain for 750f '78 ?  Is it bolt-on and ride or will I need to shim the sprockets to fit correctly?
Please, advice !
Thanks a lot ! -Serge
if it ain't broken it does not have enough features yet..
Offline Lumbee
    • My pics...
Re: where to get 530 sprockets for 750f ?
« Reply #1 on: May 16, 2006, 06:58:04 AM »
« Last Edit: May 16, 2006, 07:02:15 AM by The great "Lumbee" »
"I'm not a welder, but I play one on HondaChopper.com"
Offline kghost
« Reply #2 on: May 16, 2006, 10:09:44 AM »
Sprocket Specialists has them too
http://www.sprocketspecialists.com/
Stranger in a strange land
« Reply #3 on: May 16, 2006, 01:34:38 PM »
JT Sprockets make conversions. Very nice people to deal with too if you need help.
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
« Reply #4 on: May 16, 2006, 04:32:50 PM »
I put jt sprockets on front and back with a rk 530 o ringchain.It was a direct bolt on.k5 750 by the way.
Got them at my tuners shop.But like others said on line available.
Siter81  8)  8)
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
Offline kghost
« Reply #5 on: May 16, 2006, 07:41:15 PM »
Siter81  8)  8)
Siter81 the F uses a 630 sprocket and chain so its not quite a bolt on you need a correct hole pattern too
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #6 on: May 16, 2006, 08:13:53 PM »
The stock #650 chain is a tad wider and simply putting the 530s on there will have it a bit offset.  Milling the shoulder off the outside of the front sprocket brings it out enough to match.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline Serge
  • cb750f 1978
« Reply #7 on: May 16, 2006, 11:22:19 PM »
Thanks for the replies !  I just ordered 530 upgrade sprockets from partsnmore. I hope they will fit !  partsnmore were out of chains though..
any trusted source of reliable 530 O-ring chains ? and how many links I should order for 15 -41 teeth?   Strange that my front 630 sprocket has 14 teeth ..
Offline scondon
  • Mmmm......tasty bugs
« Reply #8 on: May 16, 2006, 11:48:35 PM »
  There are two sizes of front sprocket listed in the '78 manual, 14T and 15T. Partsnmore only lists the 15T. You'll have lower rpms on the freeway and probably get longer life from your chain with the 15T front.
  I'm running different size sprockets so can't help with the chain size, sorry :-[
Offline puppytrax
« Reply #9 on: October 26, 2006, 03:02:46 PM »
I put jt sprockets on front and back...Got them at my tuners shop...But like others said on line available.
I also would like to get a 75 750F rear sprocket, in 37, 38, or 39 tooth configuration...I've been to their site, and put in an inquiry, but is there an online dealer who stocks them in the US??
Thank You!   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
