Author Topic: Petcock screws  (Read 1466 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
Petcock screws
« on: November 03, 2011, 11:10:05 AM »
Are these things made out of something special? I picked up a pair of 6x30 (closest I could get to OEM 6x32) button-head screws to hold the petcock to the tank. The diameter of the heads was too big to fit in the recess, so I went to the industrial bolt shop by my office to get some with smaller heads and they told me that regular screws would rust. What?!? So are the OEM ones special or was this guy full of it?
'71 CB500 if it makes any difference.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: Petcock screws
« Reply #1 on: November 03, 2011, 11:24:13 AM »
Just buy a handful of them and if they do rust change them out. Personally I'm dubious they would rust significantly in a petrol environment.
Re: Petcock screws
« Reply #2 on: November 03, 2011, 12:39:00 PM »
Exactly. And I'll be more positive than that. At first, standard screws are at least rust resistant, usually zinc plated. In an exterior environment these will EVENTUALLY rust. But could be 30+ years, just look at all the case cover screws on members bikes. They may be stuck, but not rusted. (The stick came from corrosion between the steel screw and the aluminum cover, not from rust.)
Then, the screws you are talking about are immersed in gasoline, and as long as that is true, they will never rust.
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Petcock screws
« Reply #3 on: November 03, 2011, 12:56:24 PM »
The only allen screws they had were the black coated ones. Will those be ok?
Re: Petcock screws
« Reply #4 on: November 03, 2011, 01:11:25 PM »
To me, as long as the heads don't interfere as the buttonheads did, I'd put anything in there i could find. ACE would have regular Phillips. Also stainless.
Just feel like doing something different?
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Petcock screws
« Reply #5 on: November 03, 2011, 02:18:17 PM »
I just want to do SOMETHING!! Agh... So, so close to being finished :)
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Petcock screws
« Reply #6 on: November 04, 2011, 07:03:33 AM »
So I went to two other hardware stores and neither had phillips screws with smaller heads. Ended up getting a couple of these and they work fine. Also, no stripping 'em if the petcock ever has to come off. I put some gas in there and let it sit for a couple of hours last night while I was working on other stuff and no leaks, so I guess the washers worked too... we'll see when I get to the shop later this afternoon.
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Petcock screws
« Reply #7 on: November 04, 2011, 07:19:25 AM »
And now its "custom"  ::)
Re: Petcock screws
« Reply #8 on: November 04, 2011, 07:42:18 AM »
Will the round brass filter screen set down in there?  If not, you could grind down the heads.
My ACE would have had them, they have everything!   :D
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Petcock screws
« Reply #9 on: November 04, 2011, 07:47:18 AM »
Snapped that pic before I snugged 'em up. But yeah, the screen sat in there as it should.
Re: Petcock screws
« Reply #10 on: November 04, 2011, 07:50:11 AM »
Great!
Offline ataylor136
Re: Petcock screws
« Reply #11 on: November 04, 2011, 12:29:59 PM »
I was told that you need to use Nylon washers, is this correct, thanks for the info, I am putting my tank together this weekend.
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Petcock screws
« Reply #12 on: November 04, 2011, 12:41:16 PM »
I think you CAN use nylon, but OEM is the fiber washers as far as I know. Good luck!
Re: Petcock screws
« Reply #13 on: November 04, 2011, 12:47:12 PM »
i use stainless allens.
