Author Topic: Going to powder coaters this week  (Read 7642 times)
Offline going4speed
« on: December 26, 2011, 08:45:49 PM »
It has been a while since I have worked on my bike with moving and all.
Going to the powdercoater this week.
Is there a list of things I should focus on getting powdercoated?
Offline Johnie
Re: Going to powder coaters this week
« Reply #1 on: December 26, 2011, 09:03:44 PM »
Yah, be sure they do not mess up the ID tag on the neck of the frame. A member here just had it done and the powdercoater blasted right over the tag.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline going4speed
« Reply #2 on: December 27, 2011, 08:02:07 AM »
Thanks for the tip.  That was one of the first things I did on this project was take the tag off.  Its in a zip-lock in the safe.
Offline Romhog
« Reply #3 on: December 27, 2011, 08:23:26 AM »
I was contemplating the same issue and did locate this post about removing the VIN. I think this is the route I'm going to take now that I know the screws that are used to hold the vin tag on.
Check this out:
http://forums.sohc4.net/index.php?topic=29686.0
Offline Spiider
  • '73 CB750k
« Reply #4 on: December 27, 2011, 01:19:43 PM »
Some thoughts on areas to protect...if you have the steering head bearings out get them to tape off the seats for the bearings.
Also, the shock mounts, any threaded holes have to be plugged, any threaded fasteners sticking out have to be capped.
Unless you like re-tapping and cleaning up stuff with aviation paint stripper later.
Offline d3buttz
  • More than just an
« Reply #5 on: December 27, 2011, 06:25:13 PM »
Most Good powdercoat shops use rubber plugs to keep the adhesion during the spray process to not get into areas you do not want the coat to get into such as the engine mounts, bearing cups etc,I used blue masking tape and marked where they should plug.
« Last Edit: December 27, 2011, 06:27:08 PM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline K5owner
« Reply #6 on: December 28, 2011, 04:46:45 AM »
I agree with d3buttz; a good powder coating place will ask questions and work with you to get the finish you want. I would also ask to see their samples of colors. You'd be surprised how many shades of black is available.
Look forward to seeing your progress.  Thanks
-Ray
Remembering the past...   Livn' the dream
1975 Honda CB750 K5, Restored Aug/2011
1971 Honda CB175 K5, next project
1977 Honda CT70, swap meet scooter
2004 Honda NRX1800 (Rune), Cruiser
1977 Honda GL1000, daily driver
Offline going4speed
« Reply #7 on: December 30, 2011, 02:08:10 PM »
Just dropped off the frame, swing arm, bunch of brackets.  This guy seems to know what he's doing.  He was calling out parts out of my box of goodies before the lid was even open.
I asked them about plugs and protecting the areas necessary and he knew exactly what I was talking about.
Offline Johnie
« Reply #8 on: December 30, 2011, 02:09:00 PM »
Sounds like you will be OK then.
Oshkosh, WI  USA
Offline K5owner
« Reply #9 on: December 30, 2011, 02:59:40 PM »
That frame will look so good you'll want to sleep with it  :)
-Ray
Offline lucky
« Reply #10 on: December 30, 2011, 03:32:10 PM »
Why is there no photos on this thread?
Offline going4speed
« Reply #11 on: December 30, 2011, 06:05:37 PM »
Good point.  :o Only one I have of the frame at the powder-coater.
Said 5 to 10 business days.
After talking to them today I am going to take a couple more pieces to them on Tuesday.  I may not use the parts but at least if I decide to I will have them done.
« Last Edit: December 30, 2011, 06:12:29 PM by going4speed »
Offline K5owner
« Reply #12 on: December 31, 2011, 01:31:44 AM »
The other advantage of sending all the parts and maybe some extras at the same time is you'll be assured the shade of color will be the same. I've heard of cases where parts were coated on different days/runs and the colors were off a little.
Thanks for the pic. Post more when you get a chance (we're photo gluttens  ;D )
-Ray
Offline going4speed
« Reply #13 on: December 31, 2011, 10:52:04 AM »
I am on the fence when it comes to the rear brake lever and kick starter. I am tempted to get these gloss black at the same time but part of me wants to get them rechromed.
