Author Topic: need help..on 76 550?s  (Read 2365 times)
Offline messeduptriple
« on: January 10, 2012, 07:02:26 PM »
ok so ive been asking around and still havent got some answers needed.  Im in the process of guttin the 550. everything is off, cleaning is what im doing now. My main ?s are this: im planning on installing 4-2-1 exhaust..carbs have been recleaned. what jets should i put in for starters???? im using a 38 now and plan on having pods. Also the airbox had 2 hoses plugged into it.....what happens to these hoses??? do i pull them off or what??
Last question for now is any suggestions on the fusebox??where do i put this?? do i need the fuses??..i had a friend say i dont need them and he doesnt have the fuses on his bobber bike..well at least i could not see.  Also the battery...Im not very electricall but would like some info on where and how to move it???  am i cutting wires and what should i do and not do???  I really am asking for some indepth answers if possible, i cant seem to get anything useful besides some slightly odd comments that doesnt help me out.
thanks for any useful help!!!!
bike is a honda 550 1976
Re: need help..on 76 550?s
« Reply #1 on: January 10, 2012, 07:10:02 PM »
i know i cant show video but if you youtube my handle the first video is my progress beware  slight language is colorful
*   cristiancgarcia   *
« Reply #2 on: January 10, 2012, 07:13:54 PM »
Do you have any pictures of your bike in progress ?
« Reply #3 on: January 10, 2012, 07:26:19 PM »
yes   lots..how do i post????
Offline Danno
  • 74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
« Reply #4 on: January 10, 2012, 07:40:59 PM »
at least you had the good taste to butcher one of the later year 550's  you need to have at least one fuse there is a simplified wiring diagram that has been posted on the forum that will work for what you want however with the three phase alternator you must have voltage to make voltage so no voltage no spark which means you must have a battery
I have seen guys put the battery in the triangle next to the back fender with a cover that looks good if you want to use the electric start
If you do not want to use the electric start you can get a small battery and put it under a hump like for a cafe bike seat
I will warn you this those carbs are made for still air and unless you use the antipods  you will have a devil of a time making regular pods work with them which will chew up a lot of riding time trying to figure out why the bike will only run well at one given speed
compromises can be made for decent driveability but it will never run well at all speeds
these carbs need the laminar flow of the airbox designed for them
another option is to get cv carbs of of a 650 and use those they will not care so much about pods
also in the spirit of helping you download the manuals for the bike on the forum here
when you own a motorcycle the wife does not have to find you handy she just has to find you
« Reply #5 on: January 10, 2012, 07:49:04 PM »
wow....thats kinda scary and darkening my hopes on this project. do u suggest keeping the air box?? i really wanted the triangle. why is  it people can make these bikes look so sweet but its such a #$%*??????????????
I heard i dont need a battery, well if no battery how would electrical charge the speedo??   im not very well at electrical diagrams...i just wish i could shove this fuse in the corner. im so used to track riding and newer aggressive riding bikes, the simple ziptie is notorious with us and i dont want to dothis on this project. i really want a sharp bike
*** i got lost on the alternator and voltage part.... ****    i just dont want my bike to be aproject thats a bail out. im so far into it now and really want this to work out like no other!! what do you suggest the best alternative for me is?? just say f it and stick box and battery back?? i dont want to but i guess it is what it is.
« Last Edit: January 10, 2012, 07:52:12 PM by messeduptriple »
bollingball
« Reply #6 on: January 10, 2012, 08:05:19 PM »
Can you explain this ??? What kind of charge does your speedo need
Yes you need the fuses.
                                        Ken
« Last Edit: January 10, 2012, 08:10:02 PM by bollingball »
« Reply #7 on: January 10, 2012, 08:25:37 PM »
i see. does anyone have the answer for those two hoses going to the airbox that would be hanging out with no home??
« Reply #8 on: January 10, 2012, 08:28:49 PM »
so you say f it and try the carbs of the 650?? what year..sorry if these ?s aredumb just want to know specifics..im guessing 76 right???
« Reply #9 on: January 10, 2012, 08:44:33 PM »
to reply with the speedo i  did want to buy a new l e d digital speedo for it. will i still need the battery???
Online Stev-o
« Reply #10 on: January 10, 2012, 08:50:13 PM »
We're here to help, but when your first posts asks many questions without details, you will not get in depth answers.
You post you want to install a 4-2-1 exhaust and want to know what jets to install?
What kind of exhaust??
Start doing your research. Search. Read, read again. If you want to do it, it's aleady been done. Try posting one or two specific questions rather than 6 or 7 general ones.
Good luck.
bollingball
« Reply #11 on: January 10, 2012, 08:52:13 PM »
luap When you kick your bike over to start it up what gives power to the coils? I don't know much about  the 550. But my 750 needs a battery to start even with the kicker.
                                        Ken
« Reply #12 on: January 10, 2012, 08:59:34 PM »
Yes I'm sorry I plopped in many questions but those are the main ones I can't get answered
Sent from my PC36100 using Tapatalk
Offline Gordon
  • 750K1, 550K2
« Reply #13 on: January 10, 2012, 09:00:19 PM »
You're biting off more than you can chew at this point.  Slow down and spend some time learning how your bike and its individual systems work before you start trying to re-engineer them.  That way you know where you're starting from and you know what you can and cannot do.  Jumping into modifications like you're talking about without the experience and knowledge needed to tackle them correctly is a recipe for an unfinished project you end up having to pay somebody else to take off your hands.  Take your time, learn about your bike, and do it right.
And yes, you must have a battery for your sohc4 to run, even if you're only using the kick-start.
« Reply #14 on: January 10, 2012, 09:02:42 PM »
« Reply #15 on: January 10, 2012, 09:05:34 PM »
« Reply #16 on: January 10, 2012, 09:06:49 PM »
« Reply #17 on: January 10, 2012, 09:25:00 PM »
Thanks Gordon.
Offline Danno
« Reply #18 on: January 10, 2012, 11:45:28 PM »
hey bud I was not meaning to be discouraging but without converting the alternator to a fixed magnet type you need a battery and any of the cv carbs for the 650 sohc bikes would work and could be jetted to your needs the problem is what jets you need depend on how loose the exhaust is and how unrestrictive or restrictive your intake is as said by others if you want to do a build you need to do more research on how the bike should be in its stock form before you go making modifications I and others would be glad to help in whatever way we can but don't get too far ahead of your self  and by the way if you are going to sell the side covers I would be interested
Offline Danno
« Reply #19 on: January 10, 2012, 11:50:55 PM »
sorry I forgot to answer your question about the hoses one is a drain hose for condensation and should have a fat part when you squeeze it it opens and drains it is on the lower right the other is a vent hose for the engine and comes off the valve cover to let blow by out and condensation it needs to be plumbed either into one of the pods to be reburnt or it can be strung to the back by the fender and pointed to the ground to let the condensation out
Offline Danno
« Reply #20 on: January 10, 2012, 11:57:53 PM »
as far as your jets are concerned if you don't take the baffles out of the exhaust then a starting point with pods would be 115 mains and 40 slows but the mains with pods could end up 120 or 110 still 40 slows and move the needles up at least one notch (you move the clip down to move the needle up)   to do this with pods you will need at least a 42 slow jet a 40 slow jet and  110,115,120 main jets and you will have to experiment to figure out which one you need I have seen a lot of different combos used with pods none are good with everything you just have to get it where you like it most of the time
« Reply #21 on: January 11, 2012, 04:26:19 AM »
What will the bike do if it doesn't like the jets and things arent working well together?? What should I be expecting ? How will I know to go up or down on jets?
I think I will try this and I hope to learn what works and stuff. Sounds like its work and that's ok with me.
* I'm not sure what 4-2-1 exhaust to get yet.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #22 on: January 11, 2012, 10:38:44 AM »
Wat'chu talkin bout Willis? 74 - 76 are the best years. 77 and 78 would be considered later. Depending the condition when he bought it would be a shame to butcher a good resto bike. It has all the goods like exhaust, original paint and seat pan. A good seat cover and euro bars could've made a nice original.
As far as after morket exhausts and pods and all that 'stuff' it will be trial and error on your part. Most of us cringe at the mention of pods. They're pretty much for looks not performance.
« Last Edit: January 11, 2012, 10:44:41 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
bollingball
« Reply #23 on: January 11, 2012, 11:47:35 AM »
Pretty red chain. You going for some kind of theme there with the frame or tins?
                                               Ken
Offline luap
  • LAWL
« Reply #24 on: January 11, 2012, 11:52:33 AM »
is that a o ring chain? if it is they dont work on the 550's
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
