Author Topic: Squish/Quench?  (Read 16994 times)
Online HondaMan
Re: Squish/Quench?
« Reply #50 on: October 20, 2007, 10:02:14 PM »
let's see...
cb750K0 claimed BHP: 67
'79cb650 claimed BHP: 63
throw in a 5mm overbore, 10.5 compression ratio, mike reick porting, 29mm carbs, and a lightened and balanced crank? i'll double mike's bet!  ;D ;D ;D
Watch out for the parts I just sent Terry...   :D
Re: Squish/Quench?
« Reply #51 on: October 21, 2007, 02:34:57 AM »
let's see...
Sorry mate, I should apologize, I wasn't wearing my glasses and didn't read that right, I thought you said you were gonna smoke my STROKER.
I thought you were talking about the other engine I'm collecting parts for, I've got another F2 bottom end and some 73mm pistons, I'm just looking for a good CB900F crank so I can stroke it out to 1170. When I "thought" that I read that you were gonna "smoke" me with a warmed over CB650/712, I fell about laughing!
Sorry about that, I better stop drinking when I'm on this site. The only "stocker" that I've got is my K0, but I don't think I'd be interested in racing with it. Cheers, Terry. ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Squish/Quench?
« Reply #52 on: October 21, 2007, 09:46:56 AM »
The reason I thought shaving the head makes sense is that there is a slightly chamfered ring around the combustion chamber. Decking the head would flatten this out and provide a larger squish area.
Comments?
Jimmy
Re: Squish/Quench?
« Reply #53 on: October 21, 2007, 09:57:16 AM »
Better watch out. I think Terry is STROKING his smoker  ;D
Re: Squish/Quench?
« Reply #54 on: October 21, 2007, 05:32:05 PM »
Or maybe I'm smoking my stroker! :D
Online HondaMan
Re: Squish/Quench?
« Reply #55 on: October 21, 2007, 06:20:44 PM »
Comments?
Jimmy
Removing the chamfer on the 750K head converts it from a swirl-stratified mix engine to a conventional quench-squish design (while raising compression a bit). The original design uses the induced-charge spin (formed by those "pockets" around the valve faces) and edge accelleration to create a leaner-center-than-outside-charge. This swirling action provides more torque at low end and lower emissions at high RPM, while improving cooling through the whole range. I think I have a more detailed post about this, somewhere (maybe in the FAQs somewhere?).
Removing it provides more HP, though...   ;) Adding hemi head (another post around here) also reduces the swirl, but adds a rich spot in the 1/4 to 1/3 throttle range. Milling the head .010" helped, but I think it needs another .008"-.010" to finish the conversion to a squench design. We'll find out, next time I tear it down....  :D
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Squish/Quench?
« Reply #56 on: October 21, 2007, 07:43:30 PM »
Thanks Honda Man
The final question. Should I shave the head and create a conventional quench design or leave it as designed?
Cheers
Jimmy
