Author Topic: Best valve seals for not leaking?  (Read 2050 times)
Offline 1974cb550k
« on: February 24, 2012, 07:13:29 AM »
Looking to get a set of valve seals that dont leak, even if they rob a few hp? What have you guys had good luck with?
Re: Best valve seals for not leaking?
« Reply #1 on: February 24, 2012, 07:15:45 AM »
OEM or Viton should be fine. It shouldn't be an issue. If OEM seals are leaking they are either old and hard, or the guides are worn and the valve stem is rattiling around in the guide and causing the seal to leak.
Offline fmctm1sw
« Reply #2 on: February 24, 2012, 07:22:40 AM »
New ones.   :D  But seriously, if you're concerned about the potential friction they may add, the earlier heads didn't have seals on the exhaust side, intake only..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline 1974cb550k
« Reply #3 on: February 24, 2012, 07:35:44 AM »
I rebuilt my 550 and used the vesrah valve seals. it smokes a bit on start up, kinda irratates me as i replaced em less than 1k mikes ago. Just looking for suggestions before i button up my 750k4. Thanx
« Reply #4 on: February 24, 2012, 07:50:07 AM »
So, we have the issue of the guides themselves. Any idea if they were worn on the 550, and the 750?
Offline 1974cb550k
« Reply #5 on: February 24, 2012, 11:34:56 AM »
Guides were good on the 550, measured and lapped the valves. no play in the guide. I question the retaining circlips where it seals onto the guide. The 750 k4 head had broken fins, i bought a 77k head and I'm replacing all of the intake guides and valves. That's why i want good seals.
« Reply #6 on: February 24, 2012, 12:22:05 PM »
Interesting. nevertheless, I'd say OEMs should be fine. The VITONS are available on eBay and from some sellers. But most engine builders just use OEM I think.
http://www.ebay.com/itm/HONDA-SOHC-CB750-CB-750-VALVE-STEM-SEALS-VITON-/300468201164
Do a search on VITON to read up on them and decide. I went with the VITONS but I'm not running yet, so no comment.
« Reply #7 on: February 24, 2012, 12:25:53 PM »
Could be real, or hype. You decide. Also, maybe ask Mike Rieck.
http://www.goldwingfacts.com/forums/forum1/115226.html
