Author Topic: cb 550 sucks.  (Read 1546 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
cb 550 sucks.
« on: June 06, 2006, 06:53:37 AM »
my cb 550 sucks... the choke closed at half throttle.... ;D    I dont see any missing parts/spring compared to the exploded parts diagram. Is there a friction
adjustment somewheres I am missing??...anyone....
« Last Edit: June 06, 2006, 09:55:03 AM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: cb 550 sucks.
« Reply #1 on: June 06, 2006, 07:00:35 AM »
What year?...my '75 choke is integral to the carb.  Later models have a cable up to the bars. I suppose it might make a difference.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
  • NO PEE ON TEPEE
    • thesweetimpala
Re: cb 550 sucks.
« Reply #2 on: June 06, 2006, 09:53:55 AM »
I suppose I should have mentioned the carbs are off of a 71'  500, all manual, "OLD SKOOL"  to use the parlence of our times.
SOHC Member#4000
78' 550
73' CL175
Offline Noel
Re: cb 550 sucks.
« Reply #3 on: June 06, 2006, 10:01:16 AM »
Huh? You mean you were riding it and at half throttle, the choke activated itself?
'73 CB500
Offline csendker
Re: cb 550 sucks.
« Reply #4 on: June 06, 2006, 10:14:47 AM »
If I'm reading you correctly, your choke is loose and gets sucked into a closed position under speed?
I just took a real quick look at mine.  There's a spring-tensioner of sorts visible on both of the inboard carbs (#'s 2 & 3) that seems like it would impose a lateral load on the choke shaft, in effect 'tightening' it by trying to 'pull' the shaft out of the body.  I didn't look too hard to see if there's one on the backside of the outboard carb choke shafts.  The choke actuator - the little handle thingy - is riveted onto the shaft, so there has to be something on the backside to allow for dissassembly.  Maybe that can be tightened.
