Author Topic: Camshaft tensioner, camshaft and camchain install questions 750k4  (Read 842 times)
Offline 1974cb550k
I just got my tensioner back from the polisher. The cam block's, cam, and camshaft chain are now ready for install. The head has already been torqued two times and is complete up to this point. My question is should I install the tensioner before or after I install the cam, chain and sprocket. I plan on reading the multiple posts on this subject when I get over to the shop. Just thinking this would gimme a head start. Thanx
Mock up photo below.
Offline Whaleman
Re: Camshaft tensioner, camshaft and camchain install questions 750k4
« Reply #1 on: April 14, 2012, 08:59:20 AM »
Make sure the adjusting block and the rod that goes into the tensioner is clean and moves freely. I am sure you had the adjusting block and the spring out for polishing. Polish the shaft and make sure the bore does not have any corrosion. You can install the tensioner after the cam is installed .
« Reply #2 on: April 14, 2012, 09:46:37 AM »
Whether you "should" leave it off or not, is up to you. If you put it on first, be sure the plunger is locked in the full retracted into the spring position.
I suggest leaving it off till the last.
