Author Topic: cb550f stock exhaust on cb550k How to?  (Read 946 times)
Offline wrenchwench
« on: April 18, 2012, 11:44:06 AM »
Both are 1976 if that matters. I have the header installed but only after removing the rear brake pedal.
Question is finding a different rear brake pedal that will work. Note I dont have a f model parts bike. Has anyone used one off a GL1000. There is one on ebay I am looking at, I am just waiting to get a response regarding the splined shaft size.  The bend looks like it may work.
Also regarding the muffler...any thoughts on that? The one that I got with the header (still f model stock exhaust) is really rusted out & thru.
Offline the technological J
  • deliciouso!
Re: cb550f stock exhaust on cb550k How to?
« Reply #1 on: April 18, 2012, 12:40:11 PM »
http://forums.sohc4.net/index.php?topic=66442.msg731401#msg731401
 i made something like this with a little less of a right angle... i just sold the bike and i dont think i took any pics of it..
btw welcome aboard where are you from?
94 ST1100..Gone
72 750 K2 Stay tuned!
« Reply #2 on: April 18, 2012, 01:17:38 PM »
If you use the F frame, the welded on features allow use of the F model brake lever, foot peg, and kick lever, which all clear and work as they should.
Imo, the F header on a K bike is a match made in the painful style.  Better to find a K frame.
I totally understand the desire. I think the stock Honda header is the best looking 4 into 1 on the planet.  But, each and every adaptation to the K frame I've seen looked kludgy (and often works poorly) at best.
Save yourself major headache and get a header designed to fit a K model, is my recommendation.  Further, mufflers won't be much issue, either.
« Reply #3 on: April 18, 2012, 03:42:57 PM »
For what it's worth, I have an F header on my K model [bought it that way].
No issues but it does not have the stock muffler.
Offline geminimotors
« Reply #4 on: April 18, 2012, 06:31:01 PM »
Someone might trade you an exhaust for a K bike if your F exhaust is in serviceable condition. That someone might be me...
