Author Topic: Where to buy OEM float bowl gaskets.  (Read 2007 times)
Offline Dynamo
« on: April 19, 2012, 12:41:55 PM »
I'm looking for a good place to buy the oem float bowl gaskets. I recently rebuilt the carbs using the keyster kits (I only used the gaskets, all the jets and everything else is oem.) I cleaned them from top to bottom them used the keyster float bowl gaskets...when I got the carbs back on the bike it was running like a champ, however afterwards, I had a huge leak in carb 3. I pulled the float bowl and the keyster gasket was like 2x bigger than it originally was. Cheap ass rubber just expanded when it touched gas I assume. Anyway I just want to get the right oem gaskets, does anyone have a link? I checked on bike bandit, all they had were oem gaskets for the honda CB350G. are the float bowls the same size?
1973 Honda CB350F
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Where to buy OEM float bowl gaskets.
« Reply #1 on: April 19, 2012, 12:46:46 PM »
Dealer, or ebay.
« Last Edit: April 19, 2012, 12:51:39 PM by Tugboat »
Offline luap
  • LAWL
« Reply #2 on: April 19, 2012, 03:17:53 PM »
what carbs
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline fishslayeryo
« Reply #3 on: April 19, 2012, 03:20:49 PM »
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
Offline Dynamo
« Reply #4 on: April 19, 2012, 03:37:46 PM »
Sorry I should have told which carbs lol. They are from a 1973 Honda CB350F
1973 Honda CB350F
« Reply #5 on: April 20, 2012, 06:29:46 AM »
http://www.hondaparts-direct.com/fiche_section_detail.asp?section=121253&category=MOTORCYCLES&make=HONDA&year=1973&fveh=2902
Part #3 in this diagram, they didn't have 350F to select, not sure if there's a difference in the carb, but sure you could find the original part number in a manual to reference. These are OEM 10 a pop and looks like you need 2
16010-344-305 (replaces 16010-344-690)
Offline Bodi
« Reply #6 on: April 21, 2012, 05:06:59 AM »
that's a 350 twin.
The 350-4 carbs don't have a separate bowl gasket available from Honda. You need the complete carb gasket set, GASKET SET 16010-333-315. This includes all the carb gaskets and O-rings. You need four of these kits.
Offline Grey
« Reply #7 on: April 21, 2012, 06:38:54 AM »
I just did this for a 550. I went to an industrial supply house (Applied Technologies, Old Bearings Inc) and bought .070" Viton (fuel resistance) O-ring cord. Then cut to length and used super glue to glue the ends together.  Works great. Been doing it this way for years never had a leak. Stuffs cheap compared to Ebay stuff.
