Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
What did you use?
If the seal is original to the bike you are usually just better off replacing it, rubber gets brittle over time and need replacing.
It is indeed quite a common practise with motocross and offroad riders to clean the seals with either feeler gauge or a piece of photofilm, what also often works is spraying the forkleg with siliconspray and pumping the forks a few times to flush any dirt away.
If it leaked odds are you do not have the proper volume of fluid in your forks.
It's not about $ for me. I have the new seals. If someone is on an extended ride, a piece of plastic and 5 minutes on the side of the road might save a lot of grief. YMMV
Tried the 35mm film deal.... worked like a charm .... just cut a 3in. piece of 35mm film , held it tight around the fork tube and after 2 or 3 attempts got it worked down into the seal. Pushed down while turning and then removed it. This seal was leaking badly before this 'cure' and has held-up thru' a 600 mile Relay weekend, dry ( yes, there is the correct amount of fluid in the fork )..... thank you OP for posting this fix....
Good trick. My next question would be: has anyone tried a stop leak or high mileage oil in their forks to condition/soften the seals?!? High mileage oil sure seems to help the valve stem seals in my 208,000 mile car.
