Author Topic: CB650 Discontinued oil seal  (Read 8066 times)
Offline IainC
« on: May 16, 2012, 10:38:45 AM »
Hi guys,
I'm in dire need of a new drive shaft oil seal for my 79 CB650. My old one was leaking pretty bad and got destroyed in the process of removing it. Now I'm stuck with a hole in the engine that needs a seal before I can start riding again, but my local Honda dealer informed me the part is no longer available.
Oil Seal 36x57x13, part number 91205-426-013.
If anyone has a source on these or can help me track down one from an old engine your help would be awesome.
Regards,
Iain
Offline tomkimberly
Re: CB650 Discontinued oil seal
« Reply #1 on: May 16, 2012, 11:05:41 AM »
Have you tried a local bearing house? Most also sell seals in addition to bearings.
Tom
Offline lucky
« Reply #2 on: May 16, 2012, 11:30:57 AM »
Hi guys,
Regards,
Iain
When a Honda dealer says a part is no longer available means NOTHING!
For instance the clutch pressure spring for my VF1000R was no longer available and I just used one from a VF1100 SAME PART different number. Same engine block.
The part measure exactly the same to .001 thousands in every way.
Those two engines were basically the same.
Matter of fact you can go to any bearing supply house and get that oil seal at a fraction of the price.
Also another model of Honda,Yamaha ,Kawasaki,or Suzuki would work.
Same with needle jets. one float needle fits thousands of motorcycles.
Some people have even developed cross reference lists.
After 40 years I have found that the reason people like Harley Davidson is that you can get enough parts to build a 1936 harley Davidson. Crankshafts etc.,.
And many companies make the parts.
On the other hand Honda is like an American car company. They keep making new models and discontinueing others and then you cannot get parts. The old "Cowboy Economy".
Offline cb650
« Reply #3 on: May 16, 2012, 02:39:08 PM »
Sounds like you dealer dont want to be very helpful.  He could have found it in something else.
Offline IainC
« Reply #4 on: May 17, 2012, 02:58:48 PM »
My searching the internet has not lead to me finding anything compatible. Seems all the other SOHC4 bikes used a different size seal and I could spend days flipping through other part fiches trying to find one.
If a local bearing place might have one, would they be able to identify it just with the dimensions I provided? I suspect there is more to this than just using any old seal but I could be wrong.
Offline lucky
« Reply #5 on: May 17, 2012, 03:07:36 PM »
I am not surprised.
You can get the oil seal by going to a bearing supply. Go there, meet the people.
Oil seals are  usually for engines.
The specification is metric or SAE.
Metric would be inside diameter.
Outside diameter.
thickness.
Type of seal material.
Trust me a bearing supply can help you.
You need to get of the computer or cell phone and interface with reality. LOl..lol
If you have a pair of  calipers and you measure ID and OD you probably can look it up online, but the bearing supply house personal are much better at it.
« Last Edit: May 17, 2012, 03:12:48 PM by lucky »
Offline lucky
« Reply #6 on: May 17, 2012, 03:24:21 PM »
I would bet some money the CB550 oil seal is the same. ;)
Offline phil71
« Reply #7 on: May 17, 2012, 03:28:21 PM »
if you have the old one, go to a pump/bearing supply house for pluming&heating industry. Make sure it's clean so they can see the number on the side. Try not to tell them it's for a motorcycle, or they may just not bother. In new york, I always get my seals from a local place.. and they never ask what it's for, they just match up the old one. Also, it's about 40% cheaper.. I get all my fork seals from them too.
Offline lucky
« Reply #8 on: May 17, 2012, 03:30:40 PM »
Bike bandit shows the measurements.
36mmID, 57mm OD and thickness 13mm.
Now go get it!!!
Offline IainC
« Reply #9 on: May 17, 2012, 04:35:54 PM »
Thanks for your suggestions guys
Offline tomkimberly
« Reply #10 on: May 17, 2012, 06:40:13 PM »
Now go get it!!!
PUI?     ;D
Offline jerry h
« Reply #11 on: May 17, 2012, 07:45:59 PM »
Local dealers don't have much old stuff on hand, or have a parts guy that's interested in looking up "antique" stuff.  Search the online vendors with OEM catalogs.... using your number, it took me 20 seconds to find it....
http://www.westernhillshondayamaha.com/fiche_section_detail.asp?section=123459&category=MOTORCYCLES&make=HONDA&year=1979&fveh=2951
$20.62 + shipping to your door.  :D
Here is another online vender ... there are more, basically they can order most anything that's still available, your local Honda shop could do the same thing, but it's easier to say that bike is too old.
http://www.powersportscompany.com/fiche_select.asp
Hope this helps...
« Last Edit: May 18, 2012, 05:20:39 AM by jerry h »
Offline lucky
« Reply #12 on: May 17, 2012, 11:33:52 PM »
Now go get it!!!
PUI?     ;D
Have no idea what that means.
Offline tomkimberly
« Reply #13 on: May 17, 2012, 11:46:21 PM »
Lucky, google it.....
Offline IainC
« Reply #14 on: May 18, 2012, 08:09:56 PM »
Haha, seems these threads often turn into a "google it" pit.
The part is indeed no longer manufactured by Honda, and even though many websites list it with those generic parts lists, when you actually contact them they can't get it.
I did manage to track down a few, however they are expensive and low on stock. One of the few examples is CMSNL.com who last I checked had 4 left in stock for 20 Euro plus shipping to Canada. Pretty pricey.
Long story short these are hard to find, but with the help of some members I've been pointed me in the direction of a local bearing shop who can indeed help me. Just needed some guidance where to look.
@Lucky I should have taken you up on that bet. I can confirm for anyone wondering that they are not the same. The 550 uses a 33x57x7 seal
Offline lucky
« Reply #15 on: May 18, 2012, 08:22:41 PM »
Oh, well it was worth trying. ;D
« Reply #16 on: May 18, 2012, 11:59:37 PM »
honda use a lot of odd ball sizes with seals so you have to use their part,the thickness isnt as important as the inner and outer od,take your old one to a bearing supply and see if they can help.
« Reply #17 on: May 19, 2012, 10:38:09 AM »
Jerry H and others,
Not likely many of the items you see on that particular page are available. That's the problem with sites that use that microfiche system. It shows parts and parts numbers, not availability. I've order probably close to 1000 OEM Honda parts and I always use one of the sites below before I actually order whether online or at my local dealer. 90%+ of what I do end up ordering shows up.
Here's a couple I use that DO show availability from the Honda parts warehouse:
www.motogrid.com
www.bikebandit.com
Jerry G
Offline IainC
« Reply #18 on: May 21, 2012, 09:41:32 PM »
It's true Jerry G. I prefer to order Honda parts when I can, but I just can't get this one it seems. I've got a few different size seals on the way now so one is bound to fit good enough.
« Reply #19 on: May 21, 2012, 10:53:57 PM »
I know the 650 guys will appreciate your efforts.
« Reply #20 on: May 21, 2012, 11:11:36 PM »
That seal does only fit the 650 and i will bet it is a double lip seal which will be difficult to find from a generic seller, you are better biting the bullet and ordering from CMSNL BUT before you do ring Ed at Western Hills Honda as they do actualy have in stock (Or can get) a lot of the old discontinued parts---he got me the rare center selector for a 500 6 months ago AND only charged the list price
Offline davesee
« Reply #21 on: June 18, 2012, 12:59:56 PM »
curious as to how this worked out...i'm looking for one myself.
1980 honda cb650 with many weekends worth of modifications.
Offline tomkimberly
« Reply #22 on: June 18, 2012, 01:49:19 PM »
Look here to determine the seal type:  http://www.gbsa.com/oil-seal-style-cross-reference.php
Offline tomkimberly
« Reply #23 on: June 18, 2012, 02:04:43 PM »
Order your seal here: http://www.bkperformance.com.au/index.php?cPath=17
Seal, 36 57 13 for Honda 650Z  $ 26.74 AU dollars.
Tom  AKA, Google Man.    ;D
« Last Edit: June 18, 2012, 02:06:32 PM by tomkimberly »
Offline IainC
« Reply #24 on: June 18, 2012, 07:36:51 PM »
Ordered a double lip seal with dimensions 36 x 56 x 8mm. Popped in easy as the OD was slightly smaller, so I glued it in with a "healthy" amount of liquid gasket and once that was set, a good coat of clear silicone. We'll see how it lasts but a couple hundred km and its still not dripping.
Dave: Was it you I ran into down on Queen St a few weeks ago?
