Hi guys,
I'm in dire need of a new drive shaft oil seal for my 79 CB650. My old one was leaking pretty bad and got destroyed in the process of removing it. Now I'm stuck with a hole in the engine that needs a seal before I can start riding again, but my local Honda dealer informed me the part is no longer available.
Oil Seal 36x57x13, part number 91205-426-013.
If anyone has a source on these or can help me track down one from an old engine your help would be awesome.
Regards,
Iain
When a Honda dealer says a part is no longer available means NOTHING!
For instance the clutch pressure spring for my VF1000R was no longer available and I just used one from a VF1100 SAME PART different number. Same engine block.
The part measure exactly the same to .001 thousands in every way.
Those two engines were basically the same.
Matter of fact you can go to any bearing supply house and get that oil seal at a fraction of the price.
Also another model of Honda,Yamaha ,Kawasaki,or Suzuki would work.
Same with needle jets. one float needle fits thousands of motorcycles.
Some people have even developed cross reference lists.
After 40 years I have found that the reason people like Harley Davidson is that you can get enough parts to build a 1936 harley Davidson. Crankshafts etc.,.
And many companies make the parts.
On the other hand Honda is like an American car company. They keep making new models and discontinueing others and then you cannot get parts. The old "Cowboy Economy".
