Author Topic: Hilborn Injection  (Read 2821 times)
Offline bear
  • Leeton in Australia
Hilborn Injection
« on: May 21, 2012, 07:04:24 PM »
How do I fabricate or source a drive for a mechanical pump for a Hilborn injection system.
The pump needs to run of the crankshaft at a ratio of 2;1.
Brian
Offline mec
Re: Hilborn Injection
« Reply #1 on: May 22, 2012, 12:06:53 AM »
same rpm as the camshaft. either you go from there or you use the same system as used for the belt driven cams on the ducatis.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline BLUE71TURBO
« Reply #2 on: May 22, 2012, 12:31:21 AM »
Offline sohc boy
« Reply #3 on: May 22, 2012, 01:36:29 AM »
Had some in early eighty's, brian , peice of alloy plate ,  ( left side )you got pulleys ? belt ? clamp for pump made outa alloy tube ,split welded to plate, spaced accordingly for belt length....... may be a problem with crank pulley,if use Bold'or crank,or swap to other side ?depends where ign is ?........take no notice of ugly person standing behind
« Last Edit: May 22, 2012, 05:02:53 AM by sohc boy »
i live by the voice inside my head
Offline Big Jay
    • CBRzone
« Reply #4 on: May 22, 2012, 05:15:44 PM »
Call or e-mail Gary at Schroeder  http://www.schroedersteering.com/HomePage.html
He ran injected TQs for years and probably has some of that stuff laying around.
Offline BLUE71TURBO
« Reply #5 on: May 22, 2012, 10:44:15 PM »
Bear, here is the best website i have found for belt's and drive pulley's.    ;)
                      http://shop.polybelt.com/main.sc
