Author Topic: Good cam sprocket bolts for the CB...  (Read 3828 times)
« on: May 20, 2012, 06:35:42 PM »
For anybody using an adjustable cam sprocket....use Yamaha FJ1200 cam sprocket bolt  # 90105-07004-00. It has a machined neck and a flange that give far better purchase on the sprocket. Reveling ALL my secrets. ::) ;D I haven't tried it on the 550 but it may work there too.
Offline fang
    • Food Renegade
Re: Good cam sprocket bolts for the CB...
« Reply #1 on: May 20, 2012, 07:34:00 PM »
 :D  Thanks!
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
Offline jaguar
« Reply #2 on: May 20, 2012, 07:56:08 PM »
Thank you very much
« Reply #3 on: May 20, 2012, 08:09:51 PM »
Yeah, thanks. I know the stock stuff holds, but it sure doesn't feel good with only a couple of corners of the hex actually touching the sprocket, with the slot in it. A flange would be what's ordered.
Offline voxonda
« Reply #4 on: May 21, 2012, 12:28:32 AM »
Again a good tip Mike! Thanks. I use flanged Ti bolts, same effect.
« Reply #5 on: May 21, 2012, 12:49:51 AM »
Thanks Mike.... ;)
Offline tweakin
  • tear down
« Reply #6 on: May 21, 2012, 07:06:44 AM »
Thank you sir.
« Reply #7 on: May 21, 2012, 07:26:54 AM »
Yea good one Mike, I'll order some of those right off before they go the way of the DoDo. I think I told you I bought some from Honda and they're no damn good. There is a flange but the shoulder is short and the head is puny and rounded, damn hard to keep a wrench on. I went back to using older bolts.
« Reply #8 on: May 21, 2012, 07:36:15 AM »
That's the same part number as the cam sprocket bolt on my 03 FJR1300. Still a current model. So the bolts should be around for a while.
« Reply #9 on: May 24, 2012, 08:11:57 AM »
Set the cam timing on my 1000cc engine last night....maybe it will be in the frame this weekend (only took about 1.5 years)  ::). Those bolts are far better than the OEM bolts. Should be easy I have installed a frame kit. It is a bit different from the ones out there. Very similar to the CycleX kit but instead of flat faces mating there are V's (to increase surface area and really lock the pieces together). I believe there are more sets available if anybody is interested.
 Anyway...got the 2 sons to help with it. About time they earn their keep! ;D
« Reply #10 on: May 24, 2012, 09:44:48 AM »
It's about friggin time......... ;)
Whoops, I shouldn't kid my only sponsor.
« Last Edit: May 24, 2012, 09:47:25 AM by bwaller »
« Reply #11 on: May 24, 2012, 09:46:21 AM »
1.5 years? That's like... the speed of light!   ;)
« Reply #12 on: May 24, 2012, 09:49:20 AM »
Well....considering it can take light from a star millions of years to get here I guess I'm hustling right along MC. ;) ;D ;D
« Reply #13 on: May 24, 2012, 09:51:51 AM »
Hey....if had the life of a" Country Squire" like some of my nothern brothers maybe it wouldn't take so long you ball buster. ;D ;D ;D ;D ;D
« Reply #14 on: May 24, 2012, 10:26:36 AM »
Quicker than me  ;)
« Reply #15 on: May 24, 2012, 10:55:09 AM »
MR: You know I'm joking, I'm into mine 4 years now. Not counting the time spent a decade ago collecting parts.
« Reply #16 on: May 24, 2012, 11:06:04 AM »
Of course MC ;)
Offline brandEn
« Reply #17 on: May 24, 2012, 11:12:33 AM »
Mike you have way to many little tips and secrets stored in your brain that need to be shared. You need to do a "The thoughts of MReick" thread similiar to "The Thoughts of HondaMan" thread in the FAQ.
Thanks for another great tip! ;)
Offline jaguar
« Reply #18 on: May 24, 2012, 11:52:51 AM »
+1
« Reply #19 on: May 24, 2012, 12:10:13 PM »
Country Squire? I quite like it, but the truth might be more like bumpkin. ;D
Can't wait for the ride report man.
Offline Doctor_D
« Reply #20 on: May 25, 2012, 08:39:54 AM »
You mean I have to pull my engine? Again?
(JK, subscribed for future reference.)
Take care,
David
1978 CX500
1971 Norton Commando
Offline fang
    • Food Renegade
« Reply #21 on: May 25, 2012, 07:09:11 PM »
It is taking me so long to build mine, I've turned into a forum lurker....
