Author Topic: what is this lever ?  (Read 3685 times)
Offline scunny
  • don't call me expert
« on: June 17, 2006, 06:20:58 PM »
this is on a race 500/4 and it's the extra lever on the clutch.
my first thought(yes I know, bad idea) is it a choke lever, but why would you put it up there on a race bike, when the original is on the carbs.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline 750goes
  • it will live
Re: what is this lever ?
« Reply #1 on: June 17, 2006, 06:26:46 PM »
No idea what thats for...could it be an extra clutch lever or clutch adjuster ???? cant see where the cable goes.. but it seems to follow the clutch cable routing ??
dafrpa
« Reply #2 on: June 17, 2006, 07:36:11 PM »
Those look like later pumper carbs, could well be a choke lever.
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
« Reply #3 on: June 17, 2006, 08:50:05 PM »
I've seen this kind of lever a couple of times, one was a choke, the other was a valve release for higher compression engines used in race applications, easier for starting.
Peace,
Jeff
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
Offline cb650
« Reply #4 on: June 18, 2006, 09:48:12 AM »
Peace,
Jeff
Was my first thought.
                     Terry
Offline Raul CB750K1
« Reply #5 on: June 19, 2006, 04:48:00 AM »
Peace,
Jeff
I second that. Actually, my Sanglas bike have a decompressor you must use if you don't want to have a bent connecting rod when cranking the engine with the starter motor.
Raul
« Reply #6 on: June 19, 2006, 05:01:12 AM »
I think a "valve decompressor" would be a major engineering feat for a 500/4, and probably unnecessary anyway, so my money's on a choke lever. Cheers, Terry. ;D
« Reply #7 on: June 19, 2006, 05:23:00 AM »
Even when you are running high compression pistons and you got rid of the starter motor?
« Reply #8 on: June 19, 2006, 05:42:17 AM »
Yeah Raul, Rex Wolfendon's CB750 based 140 Bhp 1100 CC race bikes don't need one, why would a 500 four? Big long stroke singles like your Sanglas need 'em, but not small capacity (by cylinder volume) multi's. Cheers, Terry. ;D
« Reply #9 on: June 19, 2006, 05:50:45 AM »
Yep, that makes sense. You are compressing just one cylinder at any given moment, as opposed with singles with a comparable displacement...
Raul
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #10 on: June 19, 2006, 08:11:43 AM »
Well it looks like the throttle lever off a Suffolk Punch Lawn Mover to me, but my guess is
it's a Doohan style thumb operated rear brake lever. :o
In the UK anything over 40 years old only needs insurance and Fuel.
eldar
« Reply #11 on: June 19, 2006, 08:27:45 AM »
Well I had an old beat up yamaha twin I think that had a decompression lever. It as a 500 or something like that. I used it as a kind of brake.
Offline Noel
« Reply #12 on: June 19, 2006, 08:33:52 AM »
Is it hooked up to anything? It may just be borrowed clutch lever from a dirt bike or something, with the decompression lever not accomplishing anything.
Otherwise, why not just trace the cable and find out where it goes?
'73 CB500
Offline puppytrax
« Reply #13 on: June 19, 2006, 05:23:49 PM »
My money says a front parking brake...for victory burnouts...   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
« Reply #14 on: June 19, 2006, 06:11:06 PM »
I bet it doesn't get used much........... ;D
« Reply #15 on: June 19, 2006, 06:25:47 PM »
My thought also though...on a drum brake....yikes! It would take 4 thumbs to work. ;D
