Author Topic: Brake question  (Read 1034 times)
Offline manosteel
Brake question
« on: June 26, 2012, 08:16:31 AM »
I was wondering, im about to order some of the steel brake lines from slingshot, but is there a way to remove the hard line from the caliper and plumb the lower line directly to the caliper?
Re: Brake question
« Reply #1 on: June 26, 2012, 08:19:10 AM »
yes, just tell them what you want to do, and they can make it.
Re: Brake question
« Reply #2 on: June 26, 2012, 08:24:30 AM »
 I have banjo 90 degrees for the caliper - still in a box somewhere to be installed when I go dual disc - but from the dry mockup it will work well.
Offline manosteel
Re: Brake question
« Reply #3 on: June 26, 2012, 08:27:37 AM »
thank you very much. this is great to know.
Re: Brake question
« Reply #4 on: June 26, 2012, 08:39:00 AM »
I discussed it at length with Shaun and sent him a drawing. Take a piece of stiff cable and mock your setup. He can do 45, 90 and flat banjos. The only catch is the orientation of hose ends  - the hose is not twistable - it has to be crimped in the right position.
Good luck
Offline manosteel
Re: Brake question
« Reply #5 on: June 26, 2012, 08:42:00 AM »
so mock up my lines and figure out the angle of the banjo that it needs to connect to the caliper?
Re: Brake question
« Reply #6 on: June 26, 2012, 08:46:50 AM »
Yes, thats how i did it. I will take a picture for you tonight.
Offline manosteel
Re: Brake question
« Reply #7 on: June 26, 2012, 08:57:56 AM »
thanks, pics are worth a thousand words haha
Brake question
« Reply #8 on: June 26, 2012, 02:27:42 PM »
Well here is the brake line with right angle banjo.
Offline socalenduro
Re: Brake question
« Reply #9 on: June 26, 2012, 02:55:07 PM »
he also has another fitting that is not a banjo but does have an angle to it....
ill see if i can find the link.
im looking to do the same thing.
Offline socalenduro
Re: Brake question
« Reply #10 on: June 26, 2012, 02:59:06 PM »
its the piece on the end of this hose.
he told me he sells it individually, but i cant find it where on the page...
www.slingshot-cycles.com/index.php?main_page=product_reviews_info&products_id=55&reviews_id=6
Offline manosteel
Re: Brake question
« Reply #11 on: June 26, 2012, 03:59:21 PM »
Thanks for the help, ill have to get ahold of him.
Offline socalenduro
Re: Brake question
« Reply #12 on: June 26, 2012, 04:39:14 PM »
if you get the part # let me know..
i want to order one asap.
i sent him PM yesterday
