Author Topic: Carb-b-q cleaning worked well.  (Read 3990 times)
Offline 750K
« on: July 06, 2012, 02:15:18 AM »
I thought I'd share some pics of a carb cleaning I just did, I boiled the set of Mikuni's off my 78 KZ1000. After tearing things down I filled my wifes canning pot full of a 50/50 mix of Simple green and water and submerged the rack, the pot went on the bbq side burner. The jets, needles etc went in the ultra sonic. The Simple green not only ate any grime or varnish it stripped the crap black paint a PO covered the body of the carb in. Everything got sprayed with carb cleaner 2 to 3 times real well and passages blown out with compressed air, new o-rings and gasket went in as well. The boil worked great, I've always had good results with Simple green as a first stage soak but heating it really did the trick.
77 Cb750, 78 Kz1000
Re: Carb-b-q cleaning worked well.
« Reply #1 on: July 06, 2012, 02:48:11 AM »
they came out nice,obsessive/compulsive screw driver and wrench organization though.
« Reply #2 on: July 06, 2012, 03:23:19 AM »
Good job mate, I'll have to see if I can find some of that stuff here in Oz. Cheers, Terry. ;D
Offline brewsky
« Reply #3 on: July 06, 2012, 04:38:56 AM »
Looks good!
I've tried vinegar/hot water, pinesol/hot water, pinesol/vinegar/hot water, but never had the courage to dunk the whole rack for fear of impregnating the felt washers!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline 750K
« Reply #4 on: July 06, 2012, 09:11:04 AM »
Terry, over here I can get Simple green at Walmart, Home Depot, Canadian Tire and a few other places as well. Hopefully you can find it in Australia, it works really well as a first stage cleaner.
brewsky, I pulled all of the o-rings and fiber gaskets off prior to boiling. They were clean enough to let the bike run and idle well but leaked from the float bowl gaskets, so I figured I'd do a thorough cleaning while I had them torn down for the gasket replacement. The only rubber pieces I left in we're the throttle shaft bushings which are rubber, Simple green doesn't hurt rubber or plastics. It's Eco friendly and biodegradable, as it's just a surface cleaner and degreaser among other things. It's safe to touch and dump down the drain when your finished. Smells nice too.
Dave500, hahaha you dont know the half of it. Now I just need to run through the brakes and I can take that beast around the block and see what else needs attention.
77 Cb750, 78 Kz1000
bollingball
« Reply #5 on: July 06, 2012, 09:20:58 AM »
Need to turn that big wrench around ;D I might try that on a spare set I have. Maybe I missed it. How long did you cookum I need new felt anyway.
Ken
Offline 750K
« Reply #6 on: July 06, 2012, 09:39:29 AM »
Ken, I'd say I let them boil for an hour or so. I'd pull them out and dunk em every now and then, till they looked clean. As well as rinse them in warm water in the laundry sink to wash off lifting paint.
77 Cb750, 78 Kz1000
« Reply #7 on: July 06, 2012, 10:48:28 AM »
Here ya go Mate.  http://australia.simplegreen.com/
Online Lostboy Steve
« Reply #8 on: July 06, 2012, 11:26:52 AM »
AHHHH TWINCAM?! lol j/k Nice Job! Is that a tattoo of a locomotive?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline 750K
« Reply #9 on: July 06, 2012, 11:37:02 AM »
Yup DOHC, Ive gone over to the dark side with a 78 Kz1000.
You are correct with the locomotive, my lower forearms are all railway related tattoos. I'm a bit of a train nut you could say.
77 Cb750, 78 Kz1000
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #10 on: July 06, 2012, 12:14:34 PM »
Careful with Simple green and aluminum ( http://www.simplegreen.com/solutions_faqs.php?search_query=aluminum  ) otherwise your parts may come out black. Here's what Simple Green has to say.
Aluminum - Is it safe to use Simple Green® on aluminum?When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
« Reply #11 on: July 06, 2012, 01:42:35 PM »
Yeah it looks sweet. I've always been obsessed with them, but I have no knowledge about them.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #12 on: July 06, 2012, 07:16:19 PM »
Thanks Bobby, I'll go get some on Monday! Cheers, Terry. ;D
« Reply #13 on: July 07, 2012, 03:05:46 PM »
Always glad to lend a hand.
Offline 750K
« Reply #14 on: July 07, 2012, 03:52:06 PM »
I've been hooked on the idea of one since the first time I watched Mad Max, haha. Got lucky and one popped up on craigslist cheap, seems to have been well taken care of the more I dig into it. Terry said I'd give up riding my Cb750 once I rode a kz1000, we shall see :)
77 Cb750, 78 Kz1000
