Author Topic: Trailtech Vapor  (Read 4015 times)
Offline Dimitri13
  • 1974 CB550K
Trailtech Vapor
« on: July 25, 2012, 05:29:54 PM »
Finally picked one up. Will report back once I get my front end back together and hook it up. Anyone have experience with it?
Offline camelman
  • Man... Myth... Legend
Re: Trailtech Vapor
« Reply #1 on: July 25, 2012, 07:03:15 PM »
Nice unit. I put one on a 400f with a z1000 front end swap. It was easy enough although they supply way too much wire with the sensors. The speedo sensor magnet will hold itself in place inside a brake rotor hole but it won't stay put on the side of the rotor once the rotor gets hot and the magnetic force decreases.
The readout was easy to read.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Dimitri13
  • 1974 CB550K
Re: Trailtech Vapor
« Reply #2 on: July 26, 2012, 12:06:19 AM »
Thanks for the input camel!
One question though, I just went through all the settings, and wasn't able to edit the odometer. Is there an option to, or will I just have to set the wheel size to 9999 and pass the magnets near each other?
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Trailtech Vapor
« Reply #3 on: July 26, 2012, 12:08:35 AM »
Are these costly?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Dimitri13
  • 1974 CB550K
Re: Trailtech Vapor
« Reply #4 on: July 26, 2012, 12:26:53 AM »
I got this one for $120 at a discounted Hawaii price. In the mainland they're $130
http://trailtech.net/adventure_vapor_kits.html
The one at the bottom #75-704 (Generic conventional forks, air cooled)
Offline Tews19
  • I am no
Re: Trailtech Vapor
« Reply #5 on: July 26, 2012, 06:27:54 AM »
Sweet, I may have to look into this when I start redoing my 550. Can you show us a video of it in operation?
http://www.motorcycle-superstore.com/2/10/212/13179/DPITEM/Dirt-Bike-Motocross-Gauges-Trail-Tech-Vapor-Computer-Kit.aspx?SiteID=SLI|Speedometer&WT.MC_ID=10010
This is the same one correct?
How did you hook up the RPM cable?
1970 Honda CB750 survivor.
Offline camelman
Re: Trailtech Vapor
« Reply #6 on: July 26, 2012, 09:19:52 AM »
I don't remember setting wheel size. Just to clarify, you'll probable want the magnet in a hole not inside the actual rotor. If you do put the magnet in the rotor, then apply some epoxy. I was able to put the magnet inside a hollow pin that secured the rotor to the wheel hub.
Offline Tews19
  • I am no
Re: Trailtech Vapor
« Reply #7 on: July 26, 2012, 09:31:58 AM »
You have a pic of the set up?
Offline camelman
Re: Trailtech Vapor
« Reply #8 on: July 26, 2012, 09:58:31 AM »
No, but the Installation instructions are pretty decent.
Offline Lostboy Steve
Re: Trailtech Vapor
« Reply #9 on: July 26, 2012, 11:15:06 AM »
My buddy put one on an early 90's cr500 that was driven on the street. He liked it a a lot. I believe it gives you water temp as well. Maybe you can port that into the oil and use it for oil temp?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Dimitri13
  • 1974 CB550K
Re: Trailtech Vapor
« Reply #10 on: July 26, 2012, 05:15:28 PM »
You can download the instructions from the trailtech website. It'll show you how everything hooks up.
The RPM cable is wire with bare copper at the end that you wrap around the spark plug wire.
The speedo is two magnets.
The air cooled temperature uses a ring terminal connected to a wire to replace the crush washer on a spark plug.
It looks fairly easy to set up, I just haven't had the time yet.
Offline Tews19
  • I am no
Re: Trailtech Vapor
« Reply #11 on: July 26, 2012, 05:41:56 PM »
Damn look forward to a cool video of it in operation.
Offline Dimitri13
  • 1974 CB550K
Re: Trailtech Vapor
« Reply #12 on: July 26, 2012, 07:17:56 PM »
Haha you guys are making me want to put it on asap now :P Still screwing around with my carbs :P
I'll probably get around to it on Saturday.
