Author Topic: 1976 Honda cb550 Engine Rebuild Series Part 4- SocoMoto  (Read 1741 times)
Offline SocoMoto
« on: July 28, 2012, 07:40:44 PM »
Guys, just added another video to my engine rebuild series on youtube.
SocoMoto: 1976 Honda cb550 Cam Cover Installation (part 4).m4v
Re: 1976 Honda cb550 Engine Rebuild Series Part 4- SocoMoto
« Reply #1 on: July 28, 2012, 08:35:18 PM »
Nice video! Thanks.
Did you apply anti-sieze paste on the threads of the stainless steel screws? It needs the silver anti-sieze paste to lessen or prevent dis-similiar metal electrolysis with the aluminum.
Offline fastbroshi
  • Puppet
« Reply #2 on: July 29, 2012, 12:37:27 AM »
Where's the sound?
Just call me Timmaaaaay!!!
Offline SocoMoto
« Reply #3 on: July 29, 2012, 12:27:42 PM »
There's not supposed to be sound.. I guess I was thinking people just wanted to read the narratives instead.... oh and yes you should use an antiseize on the bolts but some people don't use it so I didn't want to show it in the video
Offline Jlovvorn
« Reply #4 on: January 20, 2013, 11:33:19 PM »
Just finished rebuild using the video series, thanks!
BUT, I double checked the book and it looks like I forgot to install the two dowels between the cylinder and the head.  These are the two non-tapered pins, not the tapered oil pins at the bottom.
I went back to the video, and I am 99% sure you didn't install them in your rebuild either.  They are not visible when you put the head on. (I really hope they were not slipped on off camera - too cruel).
Please someone tell me these two parts are not critical? (As if anything in the engine is just 'extra')
Hopeless post, but worth a shot before I tear it back apart.
« Reply #5 on: January 21, 2013, 12:38:05 AM »
dont put any pressure on those four front bolts on those little lugs untill the cover is almost home,theyll break straight off.
Offline SocoMoto
« Reply #6 on: March 09, 2013, 12:57:34 PM »
Jlovvorn- i am not sure what dowels you are talking about... correct me if im wrong, but i think you mean the 2 dowels that are used to guide and center the the head with the cylinder?.. can you take a picture and post it?
« Reply #7 on: March 09, 2013, 01:14:02 PM »
the ones between the head and cylinder are hollow and slip over the studs,these are called ferrules,the rocker cover ones are solid and are dowells.
