are you sure it had no other box/unit hooked into the ignition?once you get the points system in your hands youll have to set it up and adjust it,,down load the manual if your not sure on how to do it or are just unfamiliar with the honda set up,be sure to have 12 volts at the coils,if your engine has only been started now and again over years replace the spark plugs aswell.
