Author Topic: How to fix broken float post?  (Read 24216 times)
Offline twallace
« on: August 06, 2012, 08:35:35 PM »
So I had this great idea to clean my carbs even though my bike ran pretty good. All went well until I got to the second carb and found a broken float post that someone had epoxied or something. Picked off the epoxy and the post fell off. Is there a way to get these welded back on or should I be looking for a new carb body?
Re: How to fix broken float post?
« Reply #1 on: August 06, 2012, 08:43:45 PM »
Contact fellow member Jim F. :)
« Reply #2 on: August 06, 2012, 10:22:37 PM »
It can be repaired: if you end up not doing that, I have some bodies from a fellow Canadien from a set of carbs that I have been struggling to piece together (from many), might have the right one left over?
Offline twallace
« Reply #3 on: August 07, 2012, 07:07:26 AM »
Thanks HondaMan. Even if you don't have the right one I really appreciate the offer. Nice to know there are still some kind people out there.
The carb in question is from a cb550K1 and its the carb 1 in from the left or the one that connects to the carb with the choke lever. Is this considered #2?
Happy to pay for shipping if you have it and will someday return the favor.
Terry
Offline 2wheels
« Reply #4 on: August 07, 2012, 09:53:06 AM »
JB weld works fine.
My snow mobile has a repair like that and it's been good for years now.
It has a big globe of glue,  Your post repair looks like JB weld, they just didn't use enough.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline twallace
« Reply #5 on: August 07, 2012, 10:42:04 AM »
They used plenty of it. I picked off gobs of loose JB Weld. It held together since I bought the bike 2 years ago. Just worried that the same thing will happen if I use JB Weld. I've read mixed reports but most people say the new gas with ethanol breaks down the JB Weld in pretty short order.
Offline lucky
« Reply #6 on: August 07, 2012, 10:50:48 AM »
JB weld works fine.
YEs but I would drill a hole in both parts and put a stainless pin or steel pin ( NOT brass!) connecting the parts so it is not totally reliant on the epoxy.
A broken off old drill bit always works.
« Last Edit: August 07, 2012, 10:52:21 AM by lucky »
Offline 2wheels
« Reply #7 on: August 07, 2012, 10:53:42 AM »
"I've read mixed reports but most people say the new gas with ethanol breaks down the JB Weld in pretty short order. "
Could be and thats good to know.  I find gas stations that don't have ethanol.  Both for the bike and the snow mobile.  There are lots of gas stations in Ontario that don't have ethanol.
Offline ncstatecamp
« Reply #8 on: August 07, 2012, 12:26:56 PM »
JB weld works fine.
Why not brass? Just curious
Offline mjstone
  • I'm definitly not a
« Reply #9 on: August 07, 2012, 01:23:00 PM »
It's not the amount of JB that is needed, it's how clean the surface is before it's applied.  I found  a broken float post on my #1 carb from my '73 CB500.  I used JB to fix it.  After a couple of days to let it set up good, I dunked it in a can of Berryman's Carb cleaner for 30 minutes.  Didn't affect the JB at all.  Clean it up real good, use a file or sandpaper and get it real shinny and then ruff it up a little so  that the JB has something to grip.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline lucky
« Reply #10 on: August 07, 2012, 01:29:13 PM »
JB weld works fine.
Not brass, because the worst corrosion potential is between brass and aluminum.
On the galvanic scale it is more than a 30pt. difference.
Offline Bailgang
  • Scott
  • Indiana
« Reply #11 on: August 07, 2012, 02:06:33 PM »
I broke the float post on a set of carbs before too due to me getting hasty (lesson learned) but fortunately I have a bro in-law that is a fantastic TIG welder that came to my rescue.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #12 on: August 07, 2012, 02:17:56 PM »
Check out J B weld's website and see what they say regarding its use with gasoline....
Offline liPPy
  • 1978 cb750k
« Reply #13 on: August 07, 2012, 02:28:11 PM »
JB weld works fine.
Carb bodies are not made from pure aluminium so not a concern. Unless I'm mistaken carb jets are brass. They seem to survive okay...
« Reply #14 on: August 07, 2012, 02:31:11 PM »
Brass is fine inside carbs and has been used in carbs for close to a century.  Unless, you are going to fill them with electrolyte, of course.  But, a simple coating of gasoline will block galvanic activity.
Has anybody noticed that the jets and other parts inside the carbs are brass ?  My god, think of the danger in that!
Rumors & myths!  Start yours today!
« Reply #15 on: August 07, 2012, 02:31:54 PM »
Well, my bad: I have only 750-size carbs around. Sorry!
If I were fixing it: I would make a tiny collar (piece of tubing) that would hold a small punch concentric-ly on the diameter of the 2 pieces, punch them, and drill them with a real small drill. Then I would tap in a stiff wire (piano wire?) to the upper piece, apply some JB Weld Aluminum, and tap the upper piece down into position on the lower one and let it set up overnight.
If the holes for the float pin come out a little bit "off" afterward, you can use the good one as a pilot and drill into the JB one to match up the holes. Then, drill the damaged one a slightly larger size, put some grease on the float pin, and dab some more JB Weld into the hole and slide the greased pin into the holes, let it set up overnight again. Then tap out the pin, rub the affected end a little with some fine emery paper to make it slightly smaller as to fit easily into the JB Weld hole, and put it all back together (and adjust the float height).
Offline lucky
« Reply #16 on: August 07, 2012, 04:39:41 PM »
JB weld works fine.
Thats the point. One metal sacrifices itself to protect the other metal. In this case the aluminum based metal wastes away leaving the brass in good shape.
Offline lucky
« Reply #17 on: August 07, 2012, 04:43:53 PM »
If you look closely at some of the other carb rebuilding pics on this site you will see that the float towers are severely damaged from corrosion. Yes they have fuel now that has ethanol and that was not in the plans when these carbs were first manufactured.
It will not happen overnight, and I know you are trying to belittle me again, but it is something to consider anytime you  have dissimilar metals .
You may notice that the new replacement floats from HONDA are made using stainless now. Also The floats are plastic and not brass.
One other thing.
The early 1969 carbs did not use brass screws they used aluminum for the vacuum ports, and chrome steel or aluminum for the float bowl drains.
Start looking at where the corrosion is on the Honda carbs. It is not where the steel screws are located in the aluminum It is always near the float posts and main jet holder tube.
EXAMPLE:
« Last Edit: August 07, 2012, 05:05:21 PM by lucky »
Offline lucky
« Reply #18 on: August 07, 2012, 05:02:05 PM »
The JB Weld website: recommends the JB weld STICK for submerged repairs in gas.
Thanks SCOTTLY!
Quote:
J-B STIK
Part No. 8267-S
Description:
"J-B Stik Weld is a hand kneadable, steel-reinforced epoxy putty adhesive/sealant tha will plug holes and make permanent repairs on wet and dry surfaces. It will even cure completely submerged in water or GASOLINE! Simply knead thoroughly, with your fingers, a portion necessary for the repair and apply. J-B Stik will fully cure 20-30 minutes; and can be drilled, sanded, filed, tapped, machined, and painted. J-B Stik requires no tools or "prep time", and makes no mess."
« Reply #19 on: August 07, 2012, 05:49:34 PM »
My experience with the putty is that while it works well for plugging leaks, it doesn't work very well for gluing stuff together. In other words, it doesn't stick worth a #$%*. In the pic the carb doesn't look to be corroded at all, so it would be a good candidate for welding. I PM'd Jim; hopefully he will chime in here.
« Reply #20 on: August 07, 2012, 06:09:51 PM »
Jim pm'd me back; here is a link:
www.jmfmicroweld.com
« Reply #21 on: August 07, 2012, 06:13:18 PM »
It's NOT the metals alone that must be considered.  It is the metals plus electrolyte.  No electrolyte, no corrosion.
I'm not trying to belittle you personally, at all.  But, your position statement is basically flawed and requires correction.  I suspect it is from a lack of proper understanding regarding elemental chemistry.  Or, perhaps you've been misinformed.
The 550 has plastic floats molded to brass pivots.  Some of the new floats are completely plastic.  But, you haven't a shred of evidence this was done to combat corrosion.  I suspect it was a cost reduction measure.  You only seem to have speculation and myth with no supportive applicable science.
EXAMPLE:
...Yet your example picture has even corrosion deposits all over the carb body internals in pretty even distribution.
Galvanic action is distance critical.  Meaning the shorter the distance between the dissimilar metals, the more activity results depending on the resistivity of the electrolyte.  In fact, your picture demonstrates that the corrosion observed was not particularly associated with the brass components.  It is NOT the result of galvanic action between brass and carb body alloy.  More likely the water (the electrolyte), oxygen, from the atmospheric vents, disuse, and neglect was far more likely to be cause of the white zinc oxide deposits shown (converted from the zinc in the alloy bodies).
Since impure water (electrolyte) with dissolved oxygen collects at the bottom of the bowls, the (towers) are deprived of high resistance and protective gasoline  at that carb body location.  This leads to more corrosive activity at that location first.  While the brass does not help matters, it is NOT the primary cause of corrosion.  And specifically not a factor at the top of the fuel bowl reservoir as you suggest with your example picture.
« Reply #22 on: August 08, 2012, 05:52:21 AM »
Jim has micro welded a post for me...it is a permanent fix.
Offline lucky
« Reply #23 on: August 08, 2012, 11:10:25 AM »
Can we see a photo?
« Reply #24 on: August 08, 2012, 03:57:56 PM »
