Author Topic: Is this too much fuel line?  (Read 1116 times)
Offline Mingo
« on: August 10, 2012, 05:48:13 PM »
Taking up from the fuel line thread that has evolved into a vender listing about where to get good fuel line, I thought I'd photograph what I did and ask if this is too much.
After the post on fuel line shifted to a discussion about venders, I realized that the day I got the bike, I ordered a bunch of random stuff from Z1 and it came yesterday. Among the things i ordered was "clear fuel line 3/16" ID 5/16" OD." This fit nicely onto my carbs and I hope solved my problem.
Now I wonder if I used too much. I wanted a lot of slack so that I could move the tank around a bit.
How does it look? Is this safe.
Also, that spill-over line coming from the tank is only about a foot long, so it drains down onto my transmission. Should I get more and thread it out over the swingarm? If so, what size is that one?
Offline xsmooth69x
Re: Is this too much fuel line?
« Reply #1 on: August 10, 2012, 05:59:23 PM »
wont that line get pinched when u put the tank on the frame? as long as there no kinks or any line going above where the fuel comes out u should be good. fuel is partly gravity feed
1975 CB550 (FINISHED?!?!?)
« Reply #2 on: August 10, 2012, 06:08:04 PM »
Way too much fuel line there mate, you want as straight a run down (always downward, if it goes up you'l get an airlock and it'll conk out) to the carbs. Good to see you using an inline filter, but if the one on your petcock is in good condition, it's largely unnecessary, so if you ditch it, it'll be easier to get a short straight run to your carbs. Cheers, Terry. ;D
Offline xsmooth69x
« Reply #3 on: August 10, 2012, 06:21:08 PM »
i ran into the same problem i was going to run inline filters buttttttt the run for the fuel line is way way to short and my petcock filter is still mint to i dont have to run the inlines
http://forums.sohc4.net/index.php?topic=110761.msg1242415#msg1242415
« Last Edit: August 10, 2012, 06:24:57 PM by xsmooth69x »
Offline lucky
« Reply #4 on: August 10, 2012, 06:36:02 PM »
It is completely gravity fed.
Offline xsmooth69x
« Reply #5 on: August 10, 2012, 07:14:35 PM »
ya i knew it was gravity but i didnt know if the carbs kinda sucked the fuel?.... i left it as an open ended comment  :P
